Anybody know if my injectors are maxed out?
I did a full throttle run with my scanmaster the other day. I got an injector pulse at 11.0 on the scanmaster. Anybody know what percentage this works out to be regarding the duty cycle of my injectors? I currently have 24lb svo injectors. Thanks in advance.
Duty cycle is your pulse width, divided by the time available in two crank revolutions, so you need to know an RPM along with the pulse width to determine if the injector is being max'd out (greater than 90% duty cycle).
At 6,000RPM the time available in two crank revs is 20mS. So if you see an 18mS pulse width at 6,000RPM, your duty cycle is:
18 / 20 = 0.90 = 90%.
An 11mS pulse width doesn't even come close to maxing things out unless you are seeing it at 7,500RPM.
As a guideline, maximum possible pulse width vs. RPM:
5,000rpm - 24.0mS (80%DC = 19.2mS)
5,500rpm - 21.8mS (80%DC = 17,5mS)
6,000rpm - 20.0mS (80%DC = 16.0mS)
6,500rpm - 18.4mS (80%DC = 14.7mS)
7,000rpm - 17.1mS (80%DC = 13.7mS)
7,500rpm - 16.0mS (80%DC = 12.8mS)
Thanks Injuneer. Strange, I got that reading at about 6000 rpm.
Maybe I should check it out again, something doesn't sound right. Thanks. Do you race at englishtown Injuneer? I don't think I've seen you there.
I checked my duty cycle again. I still got an 11.5 on my scanmaster for the left bank at 6000 rpm. This doesn't make any sense, that means I'm only getting a 58% duty cycle at 6000 rpm? Something isn't right, anybody have any thoughts? Thanks in advance.
