afr problem that just kinda popped up.
Old May 22, 2011 | 05:33 PM
94zrag's Avatar
Here's what happened. I had my car set at around 12-13.1 for most situations. My aem wideband had the oxygen sensor go bad, and it was a few weeks before I got around to replacing it. I threw the new sensor in today and started the car, it idles fine at around 13-1 but any time I give it gas it runs off the scale rich, below 10-1.
What could cause this? I've checked everything I could think of engine wise.
I wouldn't think the sensor would be bad since it's reading normally at idle.
I've also done the sensor test on aem's website and it passed.
Is it possible for the sensor to be calibrated wrong?
Old May 23, 2011 | 02:51 PM
ray396's Avatar
Cool Re: afr problem that just kinda popped up.
Do you have to calibrate the sensor to the wideband?
Old May 23, 2011 | 04:27 PM
94zrag's Avatar
Not that I'm aware of.
The only thing I can think of, is that I replaced my optima battery that ran at 13.6v with a different battery that runs at 14.1v. Is it possible that with a few more volts the fuel pump is pushing a few more psi of fuel through the system?
parkers Z28
Mar 11, 2016 08:14 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
Gtpguy
Jan 26, 2015 04:50 PM
