ABS tied to the PCM?
Old Apr 8, 2005 | 11:54 PM
grygst76's Avatar
I'm tracing a gremlin 4 minutes into a run, ABS light on, is it tied to the PCM or a seperate board?? Where is the Circuit??
Old Apr 9, 2005 | 12:35 AM
Re: ABS tied to the PCM?
The ABS is controlled by the Electronic Brake Control Module (EBCM). There is a tie-in the PCM only in the case of cars with ABS and TCS.
Courtesy of Shoebox:
http://shbox.com/1/ABS_schematic.jpg
Old Apr 10, 2005 | 08:16 AM
grygst76's Avatar
When I first start my car, it runs with no abs inop light, after maybe one minute it will pop on for no reason, before I even put it in gear. Is there a trace program you can use to find the sensor/problem??
Old Apr 10, 2005 | 10:26 AM
You can scan the EBCM for codes. The codes will tell you what is turning on the "ABS INOP" light.
Nayr
Mar 3, 2023 08:34 PM
IndyZman
Oct 22, 2015 02:17 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
