2 bar map reading odd..
Thanks for the info. I ended up getting the car to run with a 1 bar tune I found online that had similar cam setup. I'm going to attempt to convert this to 2 bar.
After getting the car running, the cold side blew off the first time I hit boost
I notice now, I put the filter before the intercooler so it will still be filtered (needed to drive it home), and it rev's SLOW. Its insanely slow. At WOT, it says TPS 100% and MAP KPA is almost 100, but my car revs slower then a normal car just barely pressed on the gas.
I just swapped the opti also, and i'm still getting a Code 16, LOW RES (this is the reason I bought the new opti from thepartsladi on ebay OEM, haha). Anyone have a clue what could cause this? The alternator sensor did fall out and cause teh car not to start once, could this have thrown the code? I cleared it, but it wouldn't start again because I didn't wait long enough.
Under the alternator, near the exhaust manifold theres some sort of connector.. plugs in at the bottom of the alternator. I didn't think there was one either, till it wasn't charging and I noticed that loose...
z28projects4ever
9
Jul 16, 2002 07:48 PM
