temp question
Old Jul 22, 2003 | 05:20 PM
talos's Avatar
temp question
ok well i just installed a cam, lifts, springs, intake, carb.
well my question is the temp, when my car stock the temp wouldn't really read unless it was really hot out...
would read around 100 to 150.
but now with the big cam and what not, it reads anywhere from 180 to 200.... is it normal now cuz i have a wilder cam and what not...
whats normal temps and what would be the max....
btw im running a 195* stat
Old Jul 22, 2003 | 05:37 PM
Zedzag's Avatar
If your running a 195 stat then your car will warm up to that temperature. Once it reaches 195 the thermostat will open and let the radiator cooled water in. Put a 180 in and try that.
Old Jul 22, 2003 | 05:46 PM
talos's Avatar
ok cool thx, mike... its just when my car was stock, it didn't really read unless its really hot out....
hear about my ride home???? stupid car
Old Jul 22, 2003 | 07:18 PM
Zedzag's Avatar
You just need it tuned up. Your heating up could also be a lean runnimg condition. Check your mixture screws, float levels and timing.
All cars are stupid
Old Jul 22, 2003 | 07:24 PM
CoryM's Avatar
Nate, I thought you put a new Tstat in?? That would explain the difference. Your ride home was my fault.... I said "its not great but it will get you home". COuldnt have jinxed ya better if I had tried .
CoryM
Old Jul 22, 2003 | 09:59 PM
talos's Avatar
hahahaha ya man... oh wellz..
i installed a new 195* stat so i guess thats why the temp gets to that level... but guys on nasty said thats is a normal temp
Old Jul 22, 2003 | 11:08 PM
Erik's Avatar
Classic Tech Moderator
with the 195 stat, it sounds like it's running right where it should. You could probably go as low as 180 and then take the opportunity to replace that ugly orange water neck with a chrome one, or at least paint it with aluminum coloured paint
Old Jul 22, 2003 | 11:32 PM
talos's Avatar
lol hush you
Magenta_Hearts
Mar 29, 2017 08:54 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
