Piston to valve clearance problems
Old Mar 6, 2005 | 12:53 AM
Duke901's Avatar
I was wondering if anyone knew when piston to valve clearance problems come into play on a big block chevy. Why I ask is because the big block iam building has arias piston with a 41.5 cc dome and a comp height of 1.765. These pistons make a 11.5 compression ratio with 118 cc chamber.
Mike
Old Mar 6, 2005 | 07:09 AM
rskrause's Avatar
Moderator
Re: Piston to valve clearance problems
It depends primarily on the cam as well as the design of the crown. Of course, the compression height, gasket thickness, and piston deck will also be important. You really need to measure it once the motor is ready to assemble. However, there are certainly combos with a lot more than 11.5:1 out there, so it will proabably be ok.
Rich
Old Mar 6, 2005 | 11:12 AM
Duke901's Avatar
ok cool, the cam iam going with is the comp extreme 284 284-296 duration, 240-246 duration at .050 and a 574-578 lift with a 110 lobe.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
