Help with my 327
Old Jan 28, 2006 | 08:55 AM
94B&RZ-28's Avatar
Help with my 327
I've been on this board for years and have never been in here
Picked up a 68 coupe last week. Powerglide is getting rebuilt as I type this. What I have noticed is when i floor it in the low gear their is quite a bit of hesitation. I can also hear a very audible tick with I'm behind the wheel and driving. When I bough it the dude said he replaced the timing chain but I'm not sure if he knew what he was doing.
Help a brotha out guys!!!!!!!!!!!!
Old Jan 28, 2006 | 09:20 AM
angel71rs's Avatar
Re: Help with my 327
Congrats on the purchase & welcome to the quietest corner of CZ28.
When you say hesitation, do you mean it takes it a while for the engine to respond, or does the engine respond but there isn't much acceleration? If it's the latter, probably a result of the horrible 1st gear in the PG combined with a tall gear in the diff. You sure you want to rebuild the PG? A th350 is a straight swap in.
As far as the tick, could be a loose rocker or an exaust leak.
Old Jan 28, 2006 | 10:22 AM
94B&RZ-28's Avatar
I got the PG rebuilt for free. My neighbor owns a VERY well know shop here. When I put my foot down the car hiccups for a few and then takes off.
Old Jan 28, 2006 | 10:42 AM
IHI's Avatar
IHI
Sounds more like a carb tuning issue than a tranny issu or timing issue IMO. Sounds like a typical quadra junk ie Carter/edelbrock/rodchester carb symptom
Old Jan 28, 2006 | 11:58 AM
94B&RZ-28's Avatar
The tranny had no high gear. Just the lower. It has a holley 650 4bbl and a Weiland Intake. She idels just fine but has that tick. I do believe it may be a lifter as well because it increases with RPM's.
Old Jan 28, 2006 | 12:13 PM
IHI's Avatar
IHI
lifter or exhaust leak?
Old Jan 28, 2006 | 04:05 PM
angel71rs's Avatar
Was the car sitting before you bought it? If so, the check ball up under the accelerator shot squirter may be stuck. With the engine off, look down the throats the primaries and work the throttle to see if you get the 2 squirts. If you don't, use a phillips/needle nose to carefully remove the squirter. The check ball is directly underneath. Squirt some carb cleaner down in there to dissolve the gunk. Pop the squirter back on and recheck. If that doesn't fix it, carb has to come apart.
If the carb is ok, next thing to check would be timing.
Old Jan 28, 2006 | 04:09 PM
94B&RZ-28's Avatar
I get 2 shots, so I know the carbs good. I can't find a timing mark. I'm going to replace the lifters and push rods and call it a day.
96LT14u2Nv
Classic Engine Tech
10
Jul 4, 2003 02:51 PM
fordkiller94
Classic Engine Tech
Jun 30, 2003 01:36 PM
SantaCruz163
Jun 29, 2003 10:45 PM
96LT14u2Nv
Classic Engine Tech
Jun 26, 2003 10:55 PM
SantaCruz163
Jun 13, 2003 09:29 AM
