Engine not running
Old Jul 18, 2006 | 12:10 AM
ShiftRacing's Avatar
Engine not running
Hello all, I have a question from a friend and also me since I can't seem to figure out whats wrong with his motor. I've made my LT1 a carb'ed motor and I have gotten this thing to run strong at the track. The reson I did the swap was I bought the car with no motor in it. Then I found an LT1 block and didn't feel like spending 3 grand on the fuel injection setup. My buddy wants his LT1 carb'ed as well. So here goes...
We've got everything hooked up correctly and right. MSD Pro Billet 85551, MSD 6AL, Edelbrock 1405 (600cfm), Comp Cams "306" camshaft. Every time we go start the engine it won't run. The carb is spitting out gas which tells me its out of time. The cam was installed with the dots lined up and also the distributor was installed with the rotor button pointing towards number 1 cylinder. Cross checked plugs and they are correct 1-8-4-3-6-5-7-2. Cross checked valve lash and its good. The hub was installed correctly (since its not keyed, just thought I would mention that).
Whats going on with this thing...how can it be out of time?? Thanks for all the help!
Old Jul 18, 2006 | 03:10 PM
Re: Engine not running
Ha Ha...my buddy is funny. He didn't install the distributor correctly. I took off the timing cover and saw that when I had it at number 6 tdc, the rotor was facing towards number 1...yeah, he's a little upset. Thanks everyone! Well get this thing started here in a few minutes. I'm going to do everything myself since he's a little inexperienced. I think I just might flip the dizzy around, depends on how much I sweat outside! It's a hot one today.
Old Jul 18, 2006 | 05:32 PM
s10er8's Avatar
Let us know how it comes, that was going to be my suggestion lol
Old Jul 23, 2006 | 10:33 AM
Dave89IROC's Avatar
yeah, dots pointing at each other is #6 tdc, both dots up is #1 tdc
Old Jul 26, 2006 | 04:57 AM
ev95355's Avatar
TIME OUT... i just pulled my LT! apart and am waiting on the mail for my cam but when i was getting the motor ready for the cam install i would get pressure out of #1 when the timing marks were both up, not lined up.....WTF is the LT1 backwards??????
Old Jul 26, 2006 | 06:22 AM
Dave89IROC's Avatar
huh?
both up is #1 tdc, lined up is #6
97z28k&N
Jan 9, 2015 04:58 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
Vokabulis
Jul 25, 2002 05:46 AM
