cooling system problem ideas please
Old Aug 28, 2005 | 08:24 PM
spinout's Avatar
my engine is operating the way i want it to the problem is i keep spiting the water pump gaskets this is the third time ive siliconed both sides but they
keep spitting out am i using the wrong gaskets they are the felpro set they are just thin paper not like the ones that come with the pump you know the 1/8 inch ones is that my problem??
Old Aug 29, 2005 | 01:10 AM
talos's Avatar
Re: cooling system problem ideas please
i dunno, but do they make rubber gaskets for waterpumps?
Umm also make take the pump off and sit it on a flush surface and see if mounting face is true.
Old Aug 29, 2005 | 01:59 AM
angel71rs's Avatar
The thin paper ones are fine. Don't use too much silicone on it. I prefer Permatex or shellac for pump gaskets. Also check the surfaces of the block to make sure there isn't old gasket stuck on there. If all of that is ok, something might be restricting waterflow out of the block, causing pressure to build up.
Old Aug 29, 2005 | 03:08 AM
94Z28WP's Avatar
I've changed a number of water pumps (including on an 81 Z28 I had) using the gaskets that came with the pumps along with Permatex non-hardening form-a-gasket sealant... I put a thin coat on both sides of the gasket and installed the pump.. Never had a problem leaking or blowing out.
Old Aug 29, 2005 | 11:43 AM
tom2's Avatar
Had the same problem with the blue gaskets. Seem to dissolve or something. I used the old style black gaskets with a thin layer or RTV and no problems so far. (knock on wood)
DirtyDaveW
Dec 1, 2016 05:37 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
bernie1951
Dec 10, 2014 10:03 AM
