convert to V belt or cowl hood? (V6 to SBC swap problems)
Old May 16, 2007 | 10:22 PM
drumer919's Avatar
Well now that I finally got the right mounts and got my SBC into my firebird I am running into more problems. I don't have enough hood clearance with my accessory brackets I'm using, I have tbi brackets. On the driver side the alternator is on top and the power steering pump below that, the passenger side has a place for the AC (top) and air pump (bottom) but I have delete idlers on both of those.
Anyway the alternator is hitting the hood and so I'm debating on either switching to a v belt so I can use different brackets to make it all fit or get a cowl hood. What would you guys do in my situation? And if I do use a V belt what would I need to do to make my stock PSP work with the bracket, does it just bolt up or will I need a different pump?
I cant find that many cowl hoods for the 93-97 firebirds, is that cause there arnt many, what is the cheapest place to get one?
Old May 18, 2007 | 11:41 AM
RAT454's Avatar
I gather this is a 93-97 firebird....which SBC are you using...
G
Old May 18, 2007 | 10:58 PM
drumer919's Avatar
I'm using a GM Goodwrench 350 crate engine. And yes. Its a 94 V6.
Old May 19, 2007 | 07:00 AM
Dave89IROC's Avatar
TBI brackets are tall, you might be able to fit third gen TPI brackets in there, depending on how much more room you need
how much lower do you need the brackets to sit? I might have both types here to measure
Old May 20, 2007 | 07:41 PM
drumer919's Avatar
I only need it to be about 2 inches lower than the TBI brackets.
Old May 20, 2007 | 09:03 PM
Dave89IROC's Avatar
ok, I'll see what I can find out
Old May 25, 2007 | 08:19 PM
Dave89IROC's Avatar
which TBI brackets you using? truck or F-body?
I can't find any F-body TBI brackets in the garage, but the F-body TPI brackts are 4-5" shorter then the truck TBI brackets
Old May 26, 2007 | 07:49 PM
drumer919's Avatar
I have truck ones. What year brackets should I be looking for?
Old May 26, 2007 | 09:10 PM
Dave89IROC's Avatar
third gen f-body, 88-92, any TPI motor(305 or 350)
Old May 26, 2007 | 11:08 PM
drumer919's Avatar
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
RedLineRev
Jan 23, 2003 03:51 PM
2000silverz28
Sep 7, 2002 01:48 AM
2000silverz28
Jul 20, 2002 06:14 AM
