Is this 750 going to be too much carb?
Old Apr 24, 2005 | 09:54 AM
  #16
rskrause's Avatar
Moderator
Re: Is this 750 going to be too much carb?
I agree with the above. Just to try to clarify my point: if a carb is rated for XXXcfm and you motor needs YYYcfm, by definition if XXX=YYY there will be a 1.5" pressure drop across trhe carb. There is only a couple percent hp to be theoretically gained by decreasing this pressure drop to say, 0.5". And it will some very careful tuning to get the carb to work right with only a 0.5" drop. A vacuum seconday carb is best for street cars because the secondaries only open as much as "needed", this helps avoid the terrible "bogging" that often results when using a large mechanical secondary carb.
Bottom line: a vacuum secondary 750 is great size for a street 350.
Rich
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
240ssLs3
Jul 13, 2015 05:06 PM
IgorT.455/406
3rd Gen / L98 Engine Tech
12
Jul 8, 2002 03:49 PM
IgorT.455/406
Jun 8, 2002 05:07 PM
