10.8:1 cr too much for pump gas?
Old May 31, 2003 | 08:08 PM
zx1216's Avatar
Is 10.8:1 compression ratio too much for 93 octane? This would be on a carbed 350 using 72 cc aluminum heads and speed pro hypereutectic domed pistons. Also what 72 cc alum. heads would you recomend for a 400 hp 350?
Old May 31, 2003 | 10:15 PM
nape's Avatar
10.8:1 is too much for pump gas.
You really start to push into the limits of 93 octane at 9.75-10:1 with aluminum heads. People have gone higher, sometimes it's luck and usually it's a lot of math and experience.
Old May 31, 2003 | 11:56 PM
zx1216's Avatar
realy? I think i would be ok because i am runing 10.2:1 now on iron heads with out a problem.
Old Jun 1, 2003 | 09:43 PM
SSnthe10s's Avatar
11.5:1 runs fines on pump gas. (sonoco 94) but im sure 93 would be fine too. but if you are planning on spraying i would toss some 110 in it or somthing so u dont detonate.
Old Jun 3, 2003 | 08:50 AM
twozs's Avatar
my ls1 has 10.1 to 1 factory so 10.8 should be no problem. definitly go with high octane (93 or 94) if available
Old Jun 4, 2003 | 09:06 AM
Bcooper13's Avatar
I don't know if the alum. heads will make a difference but I'm running about 11:1 with Iron heads right now. Runs fine on 93.
Old Jun 4, 2003 | 11:04 AM
ahotrod79's Avatar
Same here, I just add some racing fuel for my trips down the track. You will be able to get by with a little more compression using aluminum heads vs iron heads though.
Old Jun 6, 2003 | 09:23 PM
nape's Avatar
How big of a cam are you guys running? You can run higher CRs with a pretty lumpy cam [more duration] because it bleeds off some cylinder pressure.
I guess I should stop reading magazines and the internet and start building motors!
Old Jun 7, 2003 | 08:25 AM
JST8A50's Avatar
I run 11:1 with Dart Iron Eagle heads, 36 deg. total timing, Comp cams 284 XE cam, and a 3500 stall converter. Car runs on 93 octane and was a daily driver for 3 years until I was able to get a beater(87 S10). Never had any detonation. I even ran a 150 shot without adding race gas or timing retard and never gave me any problems. Every car is differant but, I think with 10.8:1 and aluminum heads you will be fine.
I think a loose torque converter helps also. I remember an article in HotRod awhile back about a guy who ran a 14:1 sbc on 93 octane. Said he was able to do this because of the Nova's light weight, cam with ALOT of duration, timing was like 28 deg. I think and a very loose converter. Car ran consitant 10.80's on motor. I would never try this but, like I said every car is differant.
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
