Wiper issue
Old Aug 20, 2012 | 08:28 PM
skybritrev99's Avatar
Wiper issue
So here's my problemi have a 1984 camaro and I can't get the wipers to work. I tested the ends of the plugs and found that they had power. I took the motor out and wiredit directly tothe battery justtofind that it also appears to be in working condition. I load tested the plugs and all seems to be alright on that end. Which left me to think that there is a ground issue so I wired the motor to a direct ground and yet the wipers still don't work. Any one have any ideas or sugestions this leaves me completly baffeled. ( Hope I poasted this in the right area)
Sent from my BlackBerry 9900 using Tapatalk
Old Aug 30, 2012 | 11:13 AM
calaban's Avatar
Re: Wiper issue
May be the motor has died. That would expain how all the wiring shows correct but the wipers still do not work.
It's a PITA to change it at I'd suggest some Mechanix type gloves.
Old Sep 18, 2012 | 08:51 AM
Abbott's Avatar
Re: Wiper issue
Yeah I am also thinking about that may be the motor burned. I think you should try with new motor. It happen sometime when we are just washing the car and the water goes to the motor from any way. This is cause of the burning the motor. Have you visit any garage for solution of your car's wipers?
Old Dec 5, 2012 | 08:33 PM
Thanks guys it turns out to be the park switch that cooked that's why when hard wired it worked fine but will not work through the plugs
Red Hawk 94
Mar 18, 2019 04:03 PM
R@mpage
Apr 20, 2015 10:02 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
stopthatman
Feb 9, 2015 09:00 PM
buschman
Aug 27, 2001 09:11 AM
