Will these subs work for the amp at 2 ohms?
Old Jan 25, 2004 | 11:20 PM
1KillerV6's Avatar
These subs
And this amp
How do I wire the two subs for 2 ohms? Parallel?
I can run the two subs at 1200w off the amp if I do that right?
How do you know if the subs can run off 2 ohms? Not the normal 4, 6, 8.
Old Jan 26, 2004 | 05:38 AM
LS1 RULZ's Avatar
You can't wire two of those subs for 2ohms. You need two subs with 4ohm VC's wired in parallel to get a 2ohm load.
Old Jan 26, 2004 | 04:54 PM
1KillerV6's Avatar
Thanks, I did a search and it said that amp is 1 ohm stable....Is it? Because I looked at other specs on that sub and its 1 or 4 ohm operation.
So if thats the case, How can I hook up 2 of those subs to that amp for the most output?
Old Jan 26, 2004 | 05:35 PM
LS1 RULZ's Avatar
IF the amp can do 1ohm then you need 2 of those subs in parallel.
Old Jan 27, 2004 | 01:48 PM
eaalto's Avatar
The sound isn't going to be that great. That is way more power than you need for a 12 inch sub.
Old Jan 27, 2004 | 10:43 PM
1KillerV6's Avatar
Ok, I understand wiring now thanks to JL audio and I think LS1 RULZ for showing us the wiring diagrams in another post.
My only question now is if that JBL BP1200.1 amp is one ohm stable? I did a search and some say 2 others 1.
Although I did change my mind about those subs because I am gunna buy these cuz I found these for a good price. All I need to do is wire them parallel for the 2 ohm load cuz thats what I think the amp is stable at.
Omega9
Aug 2, 2002 12:33 AM
Brian-94TA
Jul 31, 2002 02:52 PM
Rino1313
Jul 18, 2002 05:16 PM
blue89iroc
Jul 18, 2002 04:41 PM
Manaz101
Jul 18, 2002 09:39 AM
