werid problem... im confused... need help
Old Oct 21, 2003 | 02:29 PM
vinnyxgunz's Avatar
ive had the same setup for a while now... all of a sudden when im driving for a long time and my music is turned up pretty high the sound will turn off for about 20 seconds then resume, then 2 minutes later again the sound will turn off for about 20 seconds again and so on... seems to only happen when my volume is high and ive been driving a long time... its almost like when you hit a hard bump and it stops for a couple seconds - same thing... it doesnt matter if its the cd playing or radio playing... im pretty stumped here... anyone know whats goin on?
Old Oct 21, 2003 | 04:56 PM
CrAkD X 95TA's Avatar
well whats ur setup??? it sounds like an amp overheating....when they overheat they turn off and then turn back but i dont even know if u have an amp
Old Oct 21, 2003 | 06:15 PM
battosai's Avatar
I have almost the same problem that vinnyxgunz has. But I have the factory acdelco radio and the factory bose speakers. If I have an amp it's the factory amp. I haven't put any aftermarket stereo equimpment in my car.
Anyone have any thoughts?
thanks
Old Oct 21, 2003 | 06:19 PM
Rogue Leader's Avatar
Sounds like your amp is clipping out... Its overheating, which could be any number of reasons. is it in a well ventilated place?? hows the wiring, did you install it, what gauge power wire? is it bolted or screwed down tightly, does it move???
At worst case something is crapping out inside the amp...
Old Oct 21, 2003 | 08:58 PM
vinnyxgunz's Avatar
i have a 200.4 rockford punch amp with pioneer 3 way speakers and a pioneer 9300 head unit with rockford wiring
Old Oct 21, 2003 | 09:31 PM
i cant see speakers making the amp clip....do u have any subs hooked to the amp???? best bet would be check all ur wiring make sure nothing came loose....and is the amp well ventilated like someone else asked?
Old Oct 21, 2003 | 09:38 PM
vinnyxgunz's Avatar
yeah i havent changed anything its been the same for months... no subs
InfernalVortex
Jan 17, 2015 09:35 AM
blackz151
Jan 27, 2004 12:52 AM
White_96_Z28
Dec 3, 2003 04:30 PM
lillbush5555
Nov 13, 2003 10:39 AM
Hyperspeed97z28
Oct 28, 2003 05:18 PM
