swapping BOSE headunit only
Old Apr 20, 2004 | 06:18 PM
pvkn1ght's Avatar
Question swapping BOSE headunit only
hey guys
I read up on this board & ls1.com & on this site as well on swapping the factory BOSE (not Monsoon) head unit.
To anyone who's swapped their BOSE headunit? I'm a bit unclear on if I have to use the PAC OEM-1 adapter or if I should use a wiring harness like: Metra wiring harness #70-1858 Will antenna adpater #40GM10 work also?
Thanks, I wasn't able to find BOSE ('93-'96) specific information. I have the stock 10-spkr BOSE system in my TA.
Thanks, Brian
Old Apr 20, 2004 | 09:22 PM
Javelin3o4's Avatar
i used one on a caddy. the only thing is you had to adjust the speaker levels so the volume from each matched all the way around it sound ok, but you could still tell that some speakers were slightly louder then others.
Old Apr 20, 2004 | 09:37 PM
pvkn1ght's Avatar
hmm, I see... yea, I heard you have to match the volume dials according to instructions.
I noticed the PAC-OEM1 adapter has 4 channels. I have a 10 speaker bose system. Will this work?
Old Apr 21, 2004 | 01:27 AM
Javelin3o4's Avatar
some of the speakers are probably tied together with a crossover I would think
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Bxlt1
Sep 10, 2015 08:16 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
