subsonic filter.....?
Old Oct 13, 2003 | 03:26 PM
CrAkD X 95TA's Avatar
Whats up....I just got a Rockford Fosgate 1000BD amp it has a subsonic filter...i was wondering what I should set the subsonic filter to? I have a 10" rockford fosgate POWER HX2 sub
Old Oct 13, 2003 | 03:59 PM
97FormulaWS-6's Avatar
what type of box is the sub in?
But as a safe number just go with 25-30Hz.
Old Oct 13, 2003 | 04:26 PM
x7x7's Avatar
if the subs are in a sealed box then set the SSF to off or the lowest setting. if they're in a ported box then set it a few cycles bellow your tuning frequency or so the subs don't unload during low bass.
Old Oct 13, 2003 | 07:44 PM
its in a sealed box, subthump passenger stealth...and i think the subsonic only gos as low as 70hz i could be wrong tho...
Old Oct 13, 2003 | 11:22 PM
firebirdude's Avatar
Either you are looking at the LP filter or 70Hz is as HIGH as it goes. Since you are using a sealed box, either turn it off or set it as low as it will go.
Old Oct 14, 2003 | 07:00 AM
hmm ok and whats a good setting for the low pass if it is that
Old Oct 14, 2003 | 12:49 PM
Depends on where you have your 6 1/2"s crossed over at, but a good starting point is 80Hz.
GTO2Z28
Jul 13, 2006 05:11 AM
Ray66
Jan 17, 2003 11:48 PM
CADEman98
V6 Tech
13
Jan 10, 2003 08:57 AM
