Help Setting Up Amps
Old Jul 10, 2006 | 07:35 AM
GTO2Z28's Avatar
Hifonics XX Hercules: 2000 x1 at 1 Ohm powering 2 Elemental Design 110v.2 Ohm DVC wired for a 1 Ohm Load
http://edesignaudio.com/product.php?...=Specs&cur=USD
http://users.marshall.edu/~adams111/Hercules.jpg
Impedance: 47k—0.6k
Level: 9V—0.2V
Subsonic: 10 Hz-50 Hz
Low Pass: 35 Hz—250 Hz
Bass Boost: 0 dB—18 dB
Bass Eq: 30 Hz—60 Hz
Q Control: Wide—Narrow
Phase Shift: 0 Degrees to 180 Degrees
Hifonics XX Olympus: 125x4 at 4 Ohm RMS powering a set of Directed Viper 650 Components (Rear and Channels 3 and 4) and a set of Elemental Design 6500 Components (Front and Channels 1 and 2) hooked up to a DVD HU (attempting surround sound, but will mostly utilize for music).
http://users.marshall.edu/~adams111/Olympus.jpg
Channels 1 and 2:
Channel 1: 0 Degrees to 180 Degrees
Phase Shift: Off or Stereo or Mono
Channel 2: 0 Degrees to 180 Degrees
Impedance: 47k—0.6k
Freq: 40 Hz-400 Hz (or 400-4000Hz w/ Multiplier)
Multiplier: 1x or 10x
Crossover: HPF, LP, or Slave from ¾
Crossover: Full or Crossover
Input Mode: Channel 2 or Channel 4
Channels 3 and 4:
Impedance: 47k—0.6k
Level: 9V—0.2V
Subsonic: 10 Hz—150 Hz
Overall for this Amp:
Old Jul 10, 2006 | 07:56 AM
LS1 RULZ's Avatar
Re: Help Setting Up Amps
OK, so what is it you want to know?
Old Jul 10, 2006 | 01:37 PM
GTO2Z28's Avatar
The settings, gains, etc.
They are 4 Ohm speakers, the subs, sorry for the misinformation.
Old Jul 10, 2006 | 02:21 PM
wakebordr2006's Avatar
no one can really just tell you what to put your settings as. you just have to put a dvd or cd in and use your own ears to what sounds the best the way you like to play it. its pretty much like a personal thing.
Old Jul 12, 2006 | 06:06 PM
nervekiler's Avatar
id reccomend taking that setup to the nicest stereo shop in your town.. not the cheapest, and ask that they install the amps and tune them.
make sure someone tunes them that knows what to listen for... thats the best advice i can give you.
Old Jul 12, 2006 | 11:40 PM
valter's Avatar
much more fun to hook everything yourself, here some useful stuff on settings gain:
http://mobile.jlaudio.com/support_pages.php?page_id=143
should be true for other amps
Old Jul 13, 2006 | 05:11 AM
GTO2Z28's Avatar
Thanks. Everything is hooked up and running fine (did that), just was looking for "tuning" help.
Red Hawk 94
Mar 18, 2019 04:03 PM
silvermansteve
Mar 4, 2015 05:02 PM
NewsBot
Jan 8, 2015 11:29 PM
moneyshotz
Jul 27, 2002 06:16 AM
