Which sub for stealthbox?
Old Feb 8, 2004 | 09:28 PM
JJ's95B4C's Avatar
I just ordered the stealthbox from subthump and need a sub to go along with it. I was told to look at the ED, Alpine type-r, and the rockford fosgate he2. I know I need a dual 2 ohm, but i'm not sure which sub would work best. My amp is a 140 watt kicker. I'm mostly looking at the he2 and the alpine type-r, but i'm not sure which one would be better. Any suggestions?
Old Feb 8, 2004 | 09:46 PM
LS1 RULZ's Avatar
I would recommend the Alpine Type-S over the Type-R. Here's why. The more cone area you have the more air the sub will move. The more air it moves the louder it is. The Type-R has an oversized surround which means that it has less cone area to move the air. Whats the point in having a 10" sub with the cone area of an 8" sub? If you are going to have more than one subwoofer the Type-R would be a good choice. But since this is a single subwoofer application you want as much cone area as you can get.
I used to have a JL 10W3 in my Vantage Stealthbox. While the 10W3 is an excellent sub it just wasn't a good match for the .6 cubic feet of volume in the Vantage box. I switched to the Type-S and it out performs the JL in every way in the Vantage box.
Old Feb 8, 2004 | 10:14 PM
JJ's95B4C's Avatar
The problem is that the subthump stealthbox is .5 cubic feet, and the type s needs atleast .65 cubic feet. Will it still work?
Old Feb 8, 2004 | 10:26 PM
LS1 RULZ's Avatar
Thats the nice thing about sealed enclosures. They're very forgiving when it comes to slight mismatches between the sub and the enclosure.
The 10W3 I had was supposed to work well in a .6 cubic foot enclosure but the Type-S blows it away in the same enclosure.
Old Feb 8, 2004 | 10:48 PM
JJ's95B4C's Avatar
So the .15 cubic feet extra that the type s needs is not that big of a deal? How could you compare the type s with the rf he2?
Old Feb 9, 2004 | 06:48 AM
LS1 RULZ's Avatar
I haven't had the chance to check out the RF sub before.
Old Feb 9, 2004 | 05:28 PM
rthompson's Avatar
with that power i would pick the Elemental Designs Kx over the type R.... The HE is likely going to get the loudest out of the three, but the Type R and Kx will sound a good amount better....
97srad750
May 4, 2004 11:12 AM
stuart69427
Nov 24, 2003 07:40 AM
bighurt1
Jul 15, 2003 10:05 PM
slothgrant
Jun 3, 2003 12:09 AM
zachs94camaro
Jan 12, 2003 06:02 PM
