Sub ohms?
Old Apr 5, 2003 | 10:42 PM
rotwiler's Avatar
Sub ohms?
I had a JL audio Powerwedge box and decided to put the speakers in a Millhouse box. When I went to install them I noticed the dealer had replaced the original 8ohm sub with a 4ohm one. I had a problem with one one time and had a extended warranty. So now I have a 8ohm and 4ohm sub in parellel in the same box. Is this bad? Is the amp seeing a 3ohm load? I have a MTX amp that is 2 ohm stable.
Old Apr 6, 2003 | 01:29 AM
ibanez6rg's Avatar
6 ohm load I think.
Old Apr 6, 2003 | 01:09 PM
rthompson's Avatar
Your amp will be fine, but i would go back and get a matching pair of subs.
Old Apr 7, 2003 | 04:36 PM
97firechicken's Avatar
Re: Sub ohms?
Actually its 3.4 ohms, but your still fine if your amp does 2 ohm.
Old Apr 8, 2003 | 12:41 AM
RallyRedTexan's Avatar
Re: Re: Sub ohms?
I keep getting 2.67, whats the equation you are using?
Old Apr 8, 2003 | 08:09 AM
Re: Re: Re: Sub ohms?
Originally posted by RallyRedTexan
I keep getting three, whats the equation you are using?
R = Resistor or resistance from the speaker.
1/R1 + 1/R2 = 1/RT
1/6 + 1/8 = .2916
1/.2916 = 3.4 ohms
I hope this helps if not let me know
Old Apr 8, 2003 | 05:28 PM
I was using the same equation, just with 4ohm and 8ohm subs .
Old Apr 8, 2003 | 07:01 PM
LOL oops i thought it was 6 and 8 ok, but i got 2.6 ohms. i sorry. haha i had a rough day.
Old Apr 8, 2003 | 11:17 PM
Ain't no thang, just don't want him blowing an amp or something.
Old Apr 9, 2003 | 03:22 AM
rotwiler's Avatar
Smile
thanks for the ohm answer. So far I haven't blown a fuse or had any problems with the amp heating up so it must be handling it well. Have been using this setup in the other box for awhile now so should have shown a problem if it was going to happen by now. It actually sounds better than with the 2 8ohm subs.
Old Apr 9, 2003 | 04:59 PM
Your am is pushing more power 2.6 vs. 4.0 ohms. That's almost doubling the power.
13qtr
Oct 28, 2016 08:11 PM
fift5
11
Oct 1, 2015 10:31 AM
plattted
9
Sep 20, 2015 11:23 AM
4586
Aug 13, 2015 10:11 PM
RUNMYTA
Jul 15, 2015 07:50 PM
