Radio wont turn OFF
Old Jul 25, 2003 | 07:28 PM
kmook's Avatar
Advanced Tech Moderator
Radio wont turn OFF
Well i came back to my truck today to find my radio blasting in my truck Some how it turned on while the car was off. And now when you turn the car off instead of the radio shutting off it stays on. The only way to turn it off is with the power button on it. It is a pioneer BTW. Anyone every come accross this?
I just wanted to check before i start ripping it apart.
Old Jul 25, 2003 | 09:25 PM
slayer6x6's Avatar
Take a visual inspection of the wiring behind the radio. See if the switch wire is getting 12v when the car is off (it shouldnt). Maybe you have a short to power, check to make sure there are no exposed wires (maybe rubbing aganist the constant wire, and yes I have seen that before) Did you use a harness when installing it? Oh, and btw, you shouldnt have to "rip" the radio out, with a set of Pioneer keys you should be able to "slide" it out Let me know what you find.
Old Jul 25, 2003 | 09:43 PM
kmook's Avatar
Thanks for the input. I didnt install it so i have no idea the quality or components used to wire it. Im gonna tackle this tomorrow...
Old Jul 26, 2003 | 01:28 PM
iamsparc's Avatar
yeah....sounds to me like the switched wire is now touching the constant. Someone must not have used enough elec. tape!
Old Jul 26, 2003 | 05:24 PM
kmook's Avatar
LOL, what a pain in my ***. So i downloaded a manual online for the head unit, and found what wire is the 12+ and what is switched 12+. So everything looks fine, and strangely the previous owner actually soldered everything... nothing was undone or touching
So i cut the switched wire with the car on and the radio finally turns off. so i test the wire that is suppose to be switched and it shows 12v with the car turned off so the radio has worked fine since i bought it, so what the wire changed itself from switched 12v to continuous 12v?
Well i found a switched wire in a harness nearby, spiced into that, and now it works fine.
ARGH
Old Jul 26, 2003 | 06:37 PM
moparman's Avatar
ARGH
Feel very honored, as you were visited by a gremlin.
Old Jul 26, 2003 | 10:06 PM
slayer6x6's Avatar
What was the color of the other swiched wire in the harness? Im guessing maybe the pink power antenna wire? You have a very odd problem on your hands there
Old Jul 26, 2003 | 10:09 PM
kmook's Avatar
I jacked a switched wire from the HVAC harness
Old Jul 27, 2003 | 12:42 AM
NineSevenWS6's Avatar
Hey Spanky, how is the power antenna wire getting power if the radio isnt on?
The radio is what sends power to the antenna.
Old Jul 27, 2003 | 05:40 AM
iamsparc's Avatar
This sounds like something that would happen on my old british MG!!! The electrics in those things would do weird stuff like this...and we'd always have to find new and inventive ways to hack it up like you did. Of course...I think that little MG of mine was possessed....perhaps...
Old Jul 27, 2003 | 11:03 AM
slayer6x6's Avatar
Good point, I guess I better think before I type next time
Heathen1
Jan 2, 2016 04:27 PM
warmeck
Mar 22, 2015 10:28 AM
CaRParts102
Dec 6, 2014 08:45 AM
Achilles97
Sep 13, 2002 10:49 AM
formula79
26
Aug 5, 2002 12:21 PM
