Opening garage door with 2nd channel on factory alarm
Check this out:
Instructions
I'm probably the only one that thinks this is cool. I just typed these instructions this morning so if anybody sees anything wrong, let me know.
James
Instructions
James
I just put one of my garage door openers up under the dash, wired the appropriate voltage divider up in place of the battery (I used a switched supply so it will only work with the key in), and put a momentary toggle switch in the dash console.
Works great and I never have to replace the battery.
Ever had a problem with the remote getting "out of sync" with the opener? I thought about supplying a switched power source but I was afraid it'd forget it's code hopping stuff and I'd be reprogramming all the time.
James
James
