Newbie. Want to put in deck and subs and amp
Re: Newbie. Want to put in deck and subs and amp
This amp: http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
with these subs: http://cgi.ebay.com/ws/eBayISAPI.dl...ssPageName=WDVW
is a perfect working combonation....both are STABLE at 2ohms...both will run at 600watts RMS at 2ohms...you will wire the subs in series, in a manner so that there's a 2ohm load, and it will feed each sub with 600watts RMS...
here...jsut make sure you get these subs S12L52......thats the correct part number for the 2ohm dual voice coils....and this amp: KX600.1 ....these are what you want...
so here's what you want to do....cut 'n paste those 2 part numbers i just listed, into ebays search...and spend some time comparing the Buy it now price + shipping costs, until you find the cheapest place you feel safe purchasing from...
Alright. you said dual voice coil, and those subs say single. But those subs are the ones to get? I am 16 and learning. Thanks for all your patience.
http://www.crutchfield.com/S-yPdW65X...&avf=N&search=
the "S12L52" are the dual 2ohm voice coil version....i'm pretty sure thats what i posted
Must be a typo on ebay then. So these will need to be wired in a series? friend of mine said they need to be ran parallel or i can burn a sub...
no no...those subs have 2 voice coils each stable at 2ohms....you'll be linking the subs together in a manner where there is still a 2ohm load being applied......err...****.....yeah the subs will be parrallel......thats what i was meaning....i'm staring at the wiring diagram as we speak...your friend is right...
