mounting a circuit breaker on the battery?
Old Jan 31, 2003 | 12:45 PM
PaulN64's Avatar
Question mounting a circuit breaker on the battery?
pro/cons? I was thinknig of using a double sided tape to do it.
This is what I had in mind and I don't have any room to put anywhere else.
http://community.webshots.com/photo/...62289870gWqyFW
Old Jan 31, 2003 | 01:24 PM
97FormulaWS-6's Avatar
I have mine mounted in the inner fender. I have the same thing, but with a different name on it. I have it mounted basically right next to the PS resivour.
Mounting it to the Battery may be alright... Not my style though.
Old Jan 31, 2003 | 01:30 PM
PaulN64's Avatar
I would mount it somewhere else, but there's just isn't enough room. The spot by the power steering fluid is full of wires also and a transformer so there's no room. I just want to make sure that its safe for the circuit breaker to be on the battery itself. This is more of a safety question than anything else.
Old Jan 31, 2003 | 04:24 PM
firebirdude's Avatar
There is no problem with that. Just make sure to think about the usual problems that can occur..... (wire chaffing etc.) But you would have to do that for anywhere. You are suppose to have your fuse as close to the battery as possible...... that's about as close as your gonna get!
Old Jan 31, 2003 | 11:42 PM
PaulN64's Avatar
ok....here's what I did
http://community.webshots.com/photo/...62323376ELWYzn
rest of the install page if you are interested...
http://community.webshots.com/album/62322602sVbSsy
Old Feb 1, 2003 | 01:33 AM
Looks fine. But how come no black wire for the ground? Of course it doesn't matter, but just looks better. Also, where you grounded it.... I don't see any paint scraped off! Is there?
Old Feb 1, 2003 | 01:42 AM
PaulN64's Avatar
I only scrapped off under the ring terminal. I didn't have any black wire to use. Only left over from the power wire, but it's ok. My friend has the same wires as I do but he has the blue power wire so I'm gonna change it to that whenever I get a chance. It's not black, but it's a different color. Also, my ground wire for my amp is blue anyway But I hope the circuit breaker will be safe being on top of the battery like that
Old Feb 1, 2003 | 02:03 AM
Cool. Just making sure. ;p Yeah, you will have no problems with the breaker. Why would you think you would have problems? Hey, aren't you a mod over at www.caraudioplanet.com?
Old Feb 1, 2003 | 02:08 AM
PaulN64's Avatar
yup, I'm a mod there. I recognized your name on there also figured you would have mine...guess you did
Old Feb 1, 2003 | 02:14 AM
Yep. That's a great board. Lots of positive people..... and that's hard to come by! The only problem is that it's not very active. HEY! Everybody! Check out www.caraudioplanet.com !!!!!
Old Feb 1, 2003 | 07:17 AM
LS1 RULZ's Avatar
You might want to add some shrink tubing over those exposed connectors on the breaker. If the breaker should work it's way loose it could short the battery if it makes contact with the negative terminal. The heat from the engine will cause the tape under the breaker to get loose and gummy and the breaker will start to move around.
Old Feb 1, 2003 | 10:04 AM
PaulN64's Avatar
Thumbs up
that's a good idea. I'll be sure to put some on there. My main concern is that it will be safe to put the breaker on there.
Victor Lamb
Aug 26, 2017 02:52 PM
silvermansteve
Mar 4, 2015 05:02 PM
PaulN64
Aug 8, 2002 05:39 AM
Omega9
Aug 2, 2002 12:33 AM
redz_02
Jul 24, 2002 09:42 AM
