I need advice on a setup
I own a 96 Camaro and the Bose system is pretty nice for me, but I want a little more boom. I also have t-tops and I still want to keep the area in the trunk open. What is your advice for a good sounding setup?
Exactly what I would have said. Yes, the hatch still closes fine. Stealthbox makes use of otherwise un-used space!
I just got an idea to put the amps. Why not mount them under that board that flips over the hatch area? This will keep them concealed and if you want, you can flip it over to see or show them off..
There are a few reasons why I personally wouldn't go that route. First, amps are designed to be mounted right side up or vertically. Mounting them upside down impedes their ability to cool. Second, you have to shoot screws into the flap to mount the amp and that would look like hell with screws sticking thru the other side of the flap. Third, there's no way to hide the wiring. "Showing them off" would look like crap.
There are a ton of VERY creative people out there though. I'm sure somebody could come up with a way to hide the wiring and screws. But, he is correct about the cooling problem. You could install a fan but now it's a bigger hastle then it's worth.
detroitmuscle
Jul 31, 2015 04:21 AM
