Is this going to be a big problem? (Alternator output vs system usage)
Old Sep 24, 2002 | 02:46 PM
JoFerZ's Avatar
I'm about to get a 99 Frontier 4x4 V6 and the alternator only cranks out about 80-85 amps. Well, I have 2 MTX amplifiers (Thunder 304 and 8302) that have a total of 135 amps worth of fuses. So what's the consequences of this? Will it even hurt anything? If so, what should I get, another battery, a bigger alternator, or a cap? Thanks,
Josh
Old Sep 24, 2002 | 03:28 PM
97FormulaWS-6's Avatar
I'd say Alternator, that's what's going to make the most difference. That small of a Alternator you could/most likely will have a decent light dimming problem with the subs. The 2nd thing to upgrade would be the main battery, but try the Alternator first.
Mike
Old Sep 24, 2002 | 04:00 PM
weakbeat's Avatar
To check your system check the amout of voltage drop while your system is hitting it's hardest. if it drops under 11V I would upgrade your alternator. If it doesn't drop that much you might be able to slide by with a 1F cap, but you don't have enough power to need a second battery.
J
Old Sep 24, 2002 | 05:12 PM
rthompson's Avatar
If your lights dim a little get a cap, if they dim a lot get an alternator.
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
Gtpguy
Jan 26, 2015 04:50 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
slothgrant
Aug 22, 2002 03:01 PM
