Factory sub, aftermarket amp?
Old Jun 19, 2005 | 05:38 PM
Usmuscl398's Avatar
I just bought a z28 and im replacing the stereo but i want to keep the factory sub in there until i get the t=top sub box, i am running a mtx 404 to the door speakerss and wanted to run a seperate power wire to the sub or figure out a way to wire it i dont know which wire is the speaker wire, if anyone knows which is or how to wire it up serparely plz let me know!!!
Old Jun 19, 2005 | 07:32 PM
Usmuscl398's Avatar
Re: Factory sub, aftermarket amp?
btw its a bose setup!
Old Jun 20, 2005 | 12:33 AM
Adam E's Avatar
i was a bit curious about a similar setup as well. i think i read somewhere that the way the bose stuff is designed makes it not work with aftermarket amps.
adam
Old Jun 20, 2005 | 02:13 PM
Usmuscl398's Avatar
Someone has to know, COME ON ~! ! ! !~
Old Jun 22, 2005 | 01:54 PM
SUMO-Z's Avatar
The Bose sub has its own "amp", you cannot run it off of your amp. The bose head unit is a low line input to all the speakers which have thier own "amps". At least thats how it was in my 93. If you got a high level to low level converter and then ran the wires from your amp/stereo through the converter then to the bose subs "amp" it might work.....just not 100% sure.
Old Jun 22, 2005 | 02:05 PM
meangreen661's Avatar
so u think that is why the subs in my 94 t/a sound like crap when u actually put some base out to the speakers? I know that they are not blow but when ever i turn the MX bass drive on in the Alpine HU it makes that subs go freakin crazy.
Old Jun 29, 2005 | 10:27 AM
SUMO-Z's Avatar
More than likely, I actually ran wires off the bose sub speaker to a high level input into my amp and then to two tens....It sounded ok, it just didnt drive the woofers as hard as it should of....Supposedly you cannot hook anything to a Bose system....but mine semi worked for a year, before I changed everything.
I was told that the bose speakers are like 12 ohms or something, I never gauged them so I dont know if thats true or not.
Old Jul 18, 2005 | 02:52 AM
jrtf83's Avatar
isn't this something the PAC OEM-1 would do? I'm wondering the same as i'm going to need to add an amp for a sub and an input for a computer...
Old Jul 18, 2005 | 05:08 PM
chuckd4more's Avatar
Why don't you just run the BOSE sub like stock from your HU and use speaker inputs to your amp, to your woofers? Why would you run the BOSE woof input to your amp? I don't get it. Are you just trying to save wire or something?
Apr 16, 2015 09:57 AM
cmdeshon
Dec 12, 2014 10:51 PM
regular Joe
Aug 8, 2002 03:47 PM
Snake Slayer
Jul 29, 2002 12:39 PM
