Help with audio problem
Old Jul 17, 2005 | 01:10 PM
golfer2410's Avatar
I have an aftermarket cd player and aftermarket speakers in my 95 z28. The front speakers seem to crackle and cut in and out. But I know its not the speakers themselves, cause the same problem happened with my stock speakers. The worst crackle is when i go over bumps. It really gets annoying. When its not crackling or cutting in and out, it sounds pretty nice. What do you guys think it could be? I dont know much about car audio so any help would be appreciated. Thanks guys.
Old Jul 17, 2005 | 01:16 PM
chuckd4more's Avatar
Re: Help with audio problem
It is possible youre speakers are hitting the door skin when you go over bumps. I would check that. I would think it has to be that or a bad speaker wire connection to your HU.
Old Jul 17, 2005 | 06:38 PM
carlo1170's Avatar
MOST LIKELY bad connections check em out.
Old Jul 17, 2005 | 09:57 PM
golfer2410's Avatar
thanks for the replies. I will see if i can figure out if the connections are bad. Any other ideas?
Old Jul 18, 2005 | 02:16 AM
ChicagoTransAm's Avatar
I'm 99% convinced it's a bad connection. What did you use to splice in the new speakers? Some people swear by solder, but I find it to become brittle in car applications. I always use butt connectors combined with heat shrink in areas prone to water.
Try tapping around the door area with the radio playing...no cracks? Wiggle the wiring behind the stereo.
Old Jul 18, 2005 | 06:31 AM
LS1 RULZ's Avatar
Solder connections are MUCH more reliable than crimp on butt connectors. If you have brittle solder joints it's because you have poor soldering skills. In my 30 years of installing I've seen more butt connectors get pulled apart than I can count.
Old Jul 18, 2005 | 01:00 PM
Maybe you're right...but then he should have someone else do it since he stated he wasn't that handy with electronics. When it comes to my DJ stuff, I always solder everything. Holds VERY nicely. Just I had some issues in the past with the vibrations in my cars with audio being soldered after several years...only time I have a butt connector fail is when the wrong size is used
Old Jul 18, 2005 | 09:58 PM
golfer2410's Avatar
well i had a buddy install the speakers, but like i said, the stockers crackled too. i had a different buddy install the cd player, which came months before the new speakers. is it possible that their is a bad connection right behind the cd player and not the speakers??
Old Jul 18, 2005 | 10:28 PM
LS1 RULZ's Avatar
Two words.... hell yeah!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
themushine
Sep 3, 2002 10:02 AM
Zomie
Sep 2, 2002 09:04 PM
Brian Demeter
Aug 21, 2002 02:07 PM
