Crossover door placement?
Old Jun 15, 2007 | 08:32 AM
D-Love's Avatar
Hi, putting together a system for my 98 Z28. Have all the components, including 6.5 component speakers for the front. My question is, where do I put the crossover? The wire from the tweeter makes it apparent it should be mounted close by but I'm not sure where in the door to put it? Any cutting involved here?
Old Jun 15, 2007 | 12:23 PM
valter's Avatar
You can put it inside the door, front part of it. Make sure it will not interfere with window going up/down. I have it in one of my cars and it's perfectly fine. However, to avoid unnecessary vibrations it's better to mount crossovers somewhere else. If you had a monsoon system before, in each door you already have 4 separate wires for speakers - one can be used for mid, one for tweeter. They are running to the Monsoon amp in the back. Two of them (monsoon tweeter) goes to Monsoon amp input, the other two (midrange driver) goes to Monsoon output. I just removed Monsoon amp, and spliced my crossovers into it's harness using correct wires on my other car.
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
