Bridging?
Bridging (sometimes called strapping) is a way to combine both channels of a 2 channel amp together to work as a single, more powerful channel of amplification. In most cases a bridged amp is used to power a subwoofer.
Bridgeing channels of the amplifier are most often used on subwoofers. You can wire 1 sub on two channells, or you can wire 2 subs in series to create a lighter load for the amp.
The amp you use will usually note the terminals to be used for this wiring ( one positive terminal and one negative terminal ). For more info look for series and parellel connections for sub woofers and for ohm load and stability.
Z28 Owner
Jun 1, 2003 10:18 AM
