Simple question for amp bridging/parallel wiring gurus
Old May 31, 2003 | 04:56 AM
Z28 Owner's Avatar
My amp (HiFonics Boltar VIII) is currently wired in stereo for 200 X 2 @ 4 Ohms into my 2 subs (JL Audio 12 W4's). The subs are about 4 inches apart - this is a waste, given that stereo separation is impossible to differentiate audibly and my amp is stable down to 1 Ohm...
The wiring diagrams on JL Audios site are for one channel amps. From what I gather from other sites, I bridge my amp (+ from one channel, - from the other) and get 400 watts per channel @ 2 ohms, then wire my subs in parallel and get a 1 Ohm load across my two SVC subs.
Somebody tell me what I'm looking at - I'm obviously confused.
I simply want to go from 200 X 2 stereo @ 4 Ohms to a mono load on a very capable amp into my two subs. TIA.
Old May 31, 2003 | 08:00 AM
bt96ss's Avatar
With the subs you have you can wire all the coils parallel and achieve 1 ohm. However the amp being 1 ohm stable means 1ohm stereo not mono. A 1ohm mono load is the same as a 1/2 ohm stereo load which will most likely clip the amp. You need two dual 2ohm woofers to put the amp at 2ohm mono or 1ohm stereo.
Old May 31, 2003 | 12:00 PM
firebirdude's Avatar
Incorrect. He said he has the SVC version. They only came out with single 4 ohm and dual 4 ohm versions. He should wire the the subs together in parallel for a final impedence of 2 ohm. Then bridge the amp just as he described.
Old Jun 1, 2003 | 10:18 AM
Z28 Owner's Avatar
Yep - SVC, my quest would be simpler if they were DVC models... So if I wire the subs in parallel for a 2 Ohm load, then bridge the amp - won't I ultimately have a 1 Ohm load pushing some crazy number like 800 watts@1Ohm mono?
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
BOOGER
Jul 25, 2002 02:42 PM
Zomie
Jul 21, 2002 08:03 PM
