Bose cd?
Old May 11, 2007 | 07:40 AM
slowz2895's Avatar
Bose cd?
im sure this has been covered but i couldnt find anything on it. i have the cassette player right now and i was wondering if the stock headunits wiring is the same or do you have to modify the wiring harness? any help on this would be appreciated
Old May 11, 2007 | 09:11 AM
LS1 RULZ's Avatar
It doesn't matter if it's a tape or CD HU. It wouldn't make sense for GM to make entirely different wiring harnesses just because one car had a tape HU and another a CD HU.
Old May 11, 2007 | 03:01 PM
slowz2895's Avatar
i was told by a guy today that if i put a cd player out of another camaro in my car it wont work because of a vin recognition in the computer im pretty sure hes wrong but this isnt exactly my area of expertice either anyone know about this? thanks
Old May 12, 2007 | 12:47 PM
slowz2895's Avatar
anyone know anything about this?
Old May 12, 2007 | 06:55 PM
PentaVolvo's Avatar
in newer cars yes, but deffinetely not in any f-body. swap em out it will be fine as long as you put the right one in. you can put like a monsoon cd player in a base model car, etc
Old May 12, 2007 | 08:16 PM
fredmr39's Avatar
Yea you're definitely fine...all the same from the harness - only mounting issues/sizes could be different sometimes. Other than that, Monsoon and base model HUs are exactly the same -- both Delco HUS - only differences is some Monsoon system HUs had Monsoon stickers on the Delco unit (nothing at all different about the HU itself though in comparison to the other Delco HUs on base systems).
Old May 12, 2007 | 10:57 PM
slowz2895's Avatar
thanks alot guys that realy helped me out
Old May 13, 2007 | 01:21 AM
THE_RUCKUS's Avatar
You should be fine if you are replacing it with a factory headunit with the bose provisions.
Should you want to go aftermarket the wiring harness is the same (GM02B) but Bose systems do not have a remote turn on wire (meaning you'll get no bass, at all) Don't half-*** it. Bypass the amp.
I pulled my bose trash and am running 4 infinity kappa perfect 6.5's off of an infinity 4 channel. Pioneer 6800MP Deck. Sounds Amazing.
Last edited by THE_RUCKUS; May 13, 2007 at 01:24 AM. Reason: i need to learn to read.
Old May 13, 2007 | 02:37 AM
fredmr39's Avatar
Just re-read initial post and I may have been misleading....by Bose you mean pre-97 systems, correct? I accidentally took it as Monsoon systems after '97 since so many people refer to Monsoon as Bose for some reason.
I see you have a '95 though, so you actually are referring to the Bose system.
Quickss96
Jan 29, 2016 05:56 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
cmsmith
Sep 14, 2015 09:25 PM
Bxlt1
Sep 10, 2015 08:16 AM
Eddie Z-28
Sep 4, 2002 11:58 PM
