MTX Thunderform not fitting properly
Old May 10, 2007 | 12:11 AM
sbyers77's Avatar
So I've stripped out all of the Bose system hardware of my 95 Camaro and replaced it with aftermarket gear which has been working great for a couple weeks. Now I am trying to install an MTX Thunderform and I can't seem to get it to go into place properly. I can tell its not seated as far back as it is designed to be and seems to be hitting on something, but what I do not know. I tried pulling back carpeting and anything that might prevent it from fitting with no luck. I wired it up and it sounds great, by the way!
Are there any issues with installing the MTX thunderform on cars that originally had the Bose system installed? Any other ideas?
Thank for the help!
Old May 13, 2007 | 10:53 AM
bmnicolosi's Avatar
are there any brackets ramaining from where the bose sub sat? if so you need to cut those out, take out the carpet insert for the cubby hole and you should be good to go.
phatbasslines
Jan 13, 2015 05:03 PM
Bando
Oct 7, 2002 07:36 PM
CLEAR
Sep 2, 2002 07:59 PM
Firebird9463
Aug 5, 2002 08:17 PM
Snake Slayer
Jul 29, 2002 12:39 PM
