alarm Help
Old Jan 17, 2004 | 01:07 PM
the1turkey's Avatar
alarm Help
when ever i arm the thing it goes off after like 2 seconds any time i lock the car the only time it shuts up is after i pulled the radio fuse and set every thing to 1 chime so now i don't have an alarm but every time I set it back it still goes off no matter what
any suggestions this is really getting on my nerves
Old Jan 17, 2004 | 03:14 PM
Ron78Z&01SS's Avatar
Maybe something's shorting out causing the alarm to trigger due to volatage drop.
I had a 92 Z28 with an alarm that kept going off. It ended up being the cig lighter was stuck in causing the battery to drain enough to trigger the alarm.
I'd start by checking to make sure that everything that's "off" is actually off.
Old Jan 17, 2004 | 09:37 PM
the1turkey's Avatar
so i might need a new battery i've been thinking htat for a while but this just started thanks i'll check tho keep the advice coming
Old Jan 18, 2004 | 08:27 AM
SP99SS's Avatar
I had the same problem a couple years ago back when it was still under warranty. Took it to the dealer thinking it was probably a faulty shock sensor. They replaced the sensor and the problem still continued. They said that in order to truly diagnose it they'd probably have to pull out a bunch of wires. I didn't like the sounds of that so I decided to disable the sensor.
If you can't get it fixed, check your owners manual and you'll find a section describing how to disable the shock sensor. The alarm will still sound if a door is opened, but won't sound if something hits the car.
SP
Old Jan 18, 2004 | 09:01 PM
the1turkey's Avatar
thanks but no manual bought the car used where is the shock sensor
thanks for the help
Old Jan 19, 2004 | 11:58 AM
SP99SS's Avatar
The shock sensor is located in the passenger side of the rear storage area. It's under the removable plastic in the section that houses the spare tire and jack.
It's got a sensitivity adjustment on it. You could try adjusting that to see if it helps or not. But without access to the manual here at work I can't tell you any more.
SP
Old Jan 20, 2004 | 02:15 PM
the1turkey's Avatar
thanks for the help man
any thing else you can add would be great
Old Jan 21, 2004 | 01:48 PM
SP99SS's Avatar
I'll try to remember to check my owners manual and give you directions on how to disable the shock sensor.
SP
Heathen1
Jan 2, 2016 04:27 PM
IndyZman
Oct 22, 2015 02:17 PM
MichiganSkip
Aug 6, 2015 09:38 AM
OutlawPerforman
Jun 15, 2015 12:49 AM
