99 TA monsoon radio
Re: 99 TA monsoon radio
If you can get behind a speaker and get to the signal wire, you can use a Line Out Converter. These take the signal from the speaker wire, and convert it into RCA line outs. They then hook into your amp so you can power more speakers. The only problem is you'll get only one speaker's signal, and if the music fades, you'll lose the other speakers you have hooked up.
Schoche makes a few harnesses that hook directly between your head unit and the harness that's in the car and provide for line out outputs to amps, check 'em out.
This is a generic one, but should work with a little splicing.
http://walmart.scosche-cars.com/prod...ductID=1863065
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
