Ward's 10 Best Engines for 2008
Old Dec 11, 2008 | 12:56 PM
  #31
JakeRobb's Avatar
Super Moderator
Originally Posted by Robert_Nashville
True. But when gasoline prices rise 30% in a matter of days as they did late this summer; every extra penny is noticeable.
Let's just say that expensive gasoline is a PITA regardless of what grade you are buying.
Granted. Just keeping you on your toes.
Old Dec 11, 2008 | 10:39 PM
  #32
bossco's Avatar
Originally Posted by SSbaby
Oh it's a manufacturing achievement alright! That's why Chrysler did an iron block instead of the newer (and higher tech) alloy... because it was far easier & cheaper to build. That's why both Ford and Chrysler haven't followed GM down this path, it's because it isn't a simple process to mass produce alloy V8s.
By doing an all alloy engine, GM managed to shave 100 lbs from the engine alone - implied, it overcomes the OHV's deficiencies compared to DOHC 'equivalents'. That's a great achievement in any language!
Did GM switch the truck engines to all aluminum as well? Ford went all aluminum on the Mustang's 4.6 and I hear the GT500 around '11 will have an all aluminum engine as well.
In any event I'm not dazzaled by an all aluminum engine, cost most certainly is a factor, but there could have been other reasons for using cast iron as well. The knock your socks off technology from GM for me is the cylinderheads.
Old Dec 11, 2008 | 10:45 PM
  #33
My Red 93Z-28's Avatar
I'm wanting to see some CGI blocks, lighter and stronger than cast iron, but unless something has changed...its a bitch to machine. CGI will probably just stick with diesels though.
Old Dec 11, 2008 | 10:48 PM
  #34
Originally Posted by Eric Bryant
If someone wants to get a chubby for tech specs, then pick the 6.4L Powerstroke - it's something else (sequential turbos with variable vane geometry on one, piezo injectors, more catalysts and heat exchangers than a coal electrical generation plant).
I'm glad you like it
It is definitely an amazing piece, it takes forever just to strip the engine down to the long block, between the two EGR tubes, turbo setup, filters, etc. I believe they recommend removing the cab/doghouse to do certain work on the engine.
Old Dec 12, 2008 | 05:42 AM
  #35
SSbaby's Avatar
I'm a huge fan of GM's LSX but, on the flipside, is GM's 3.6L DI V6 really that good? Is it better than Honda, Toyota and Nissan V6s? Every report I've read so far has been less than flattering of GM's V6 in comparison...
Old Dec 12, 2008 | 05:52 AM
  #36
Eric Bryant's Avatar
Yep. The same is also true of the 6.0L Powerstroke. I don't quite understand how this happened, considering that the hood opening on the Super Duty is the size of the average garage door
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
guionM
69
Nov 30, 2006 02:01 PM
APS95Z28
Sep 5, 2002 10:21 AM
ReznorZ28
Aug 27, 2002 03:53 PM
