One compelling reason to keep pushrod engines.
Old Apr 13, 2004 | 04:29 PM
  #151
90rocz's Avatar
Because it saves about $800 per car.
I'd say that sums it all up..."Bottom Line"...it's all Big Corporations care about, and let's face it, $800/unit per hundreds of thousands of units per year, is quite substantial...
And the differences in power or reliability seem negligible between the OHV and OHC, so where's the big incentive to change???
Nice discussion btw, very entertaining..
Old Apr 13, 2004 | 09:13 PM
  #152
Bob Cosby's Avatar
In the interest of trying to keep this Forum "above" what often takes place in others (as I know this is the wish of the folks that run the Forum), I'll do my best to do this in a "matter-of-fact" manner. Sorry to those that wish for more entertainment. I'll gladly go have some more fun in a more appropriate Forum - IMHO, I'm showing a LOT of restraint here. Please.....make my day.
Originally posted by PacerX
1) Do I own a dyno? No.
Ditto.
2) Have I done dyno testing? I've had my car tested repeatedly, and been there for it, and know enough that it takes considerable effort to ensure repeatability from run to run ON THE SAME CAR WITH NO CHANGES. Mine has run from baseline with no mods up to the bolt-ons. The latest round of mods will be tested again when finished.
On the same dyno, with the same operator, using the same procedures, I disagree. It should be noted that you CANNOT accurately compare results from the same car on different dynos.
I've also conducted tests using other types of dynomometer on my own (electric motors), same concept, but far less complicated.
Awesome. And what data did this produce to support the 15% "rule of thumb" that you have stated?
I contend that you do not have such data - nor have I seen it here. It requires that one has access to both an engine and chassis dyno, and comparison runs are made with no changes. I've seen some data like this (specifically from a fellow racer, Robin Lawrence, who also runs the NMRA series) - though haven't done the testing myself.
That's good Booby, you can use a dictionary. So, what's the hysteresis on the dyno you're using?
Don't know. Further, as I can show repeatability within less than 1%, I don't believe it matters in the context of this discussion.
Not knowing the design of either, I'll decline that one. Feel free to educate me here.
I only know the very basics of the design differences (weight of gearing, rail design, minor issues like that), and thus I am also not qualified to accurately discuss it. However, as many of my fellow racers who have done similar testing know, there is a 10-15 RWHP difference between the trannies mentioned above. That is easily enough to vary the 15% "rule" by 3-4% one way or the other.
Wipe your chin. You'll mess up your keyboard if that stuff hits it.
Thanks for the tip.
Actually, it's the only type of racing I do.
Cool. Could you please state your credentials? Do you test-n-tune, bracket race, class race, what? Do you use the dyno to tune, to baseline, to find the effects of mods, what?
As I actually have a job, I'm precluded from doing it as often as I like, but still do it.
Ditto, but not the point of this discussion, nor is is relevant.
Best time while dead stock was a 13.1@108 at M7 - not a bad time for a full book SS with 1400 miles on the clock.
Good for you.
Proceeded to the low twelves last year on the stock rear end and tires with bolt-ons
Good for you x2.
and am rebuilding the machine as we speak... considerably more powerful than low 12's this time around, and no "glass-jaw" 10-bolt to worry about.
I wish you the best of luck. Kindly tell us the results when you have them.
Am I a professional? God no. I do enjoy it though. Will I ever be? God no. Do I want to be? God no. Won't take the pay cut.
I am not a professional either, though I would love to be.
Having just bought a decently fast motorcycle, I'll run that around the twisty tracks and see if I enjoy it this summer while the SS works it's way down the mod path.
Irrelevant to the conversation at hand.
Booby, I've already seen at least one of your wins mentioned on Speed - saw the film of it too. Great. Have a cookie.
I've never been on 'Speed'. ESPN2.
Being a class-winning idiot makes you no less of an idiot.
Thanks.
The question still exists:
Is 40hp enough to allow someone in your class to dominate everyone else? And the answer would be "YES". Spot your competition 40hp if you think otherwise and let's see how you do.
No, that was not the question. Kindly go back and read my first response. There was nothing there about someone having 40 more HP in my class. It was about a blanket statement you made that 40 hp would make all the difference. That is simply incorrect, and I have provided documented, verifiable data to back up my assertion. You have provided....words. Folks can draw their own conclusions.
Either do that, or shut up.
It should be obvious now that you telling me to "shut up" is quite useless.
You know the answer, and so do I. 40hp, all other things being equal, would allow someone to dominate your class.
See above.
Good day.
Fast LS1...just a note about being "under-square". The engine builder that did my 4.6 has a 97 Cobra with a stock bore (.020 over) 5.4 DOHC. He routinely spins it to ~8000 rpm, and has yet to experience a rod, bearing, or piston failure related to that rpm. The car runs 10.2x @ 134+ mph at 3350 lbs, N/A. 4.56 gear on a 26x10 slick if you would like to do the rpm vs mph math.
The engine is really quite mild, idles at ~900 rpm (cams are ~.520 lift and .230 duration), and keeping in mind that it needs to be fed 110 octane race gas, is very streetable. It makes in excess of 500 RWHP SAE (I don't have a link to a dyno run for that one - sorry). Regardless, I think that runs a bit counter to the idea that something being "under-square" cannot turn a respectable RPM.
BTW, so that those that wish to look it up can do so, the guy's name is Al Papitto, and he posts regularly on many of the Mustang Forums. He is a former IDBA Pro Stock bike champion, and up until very recently, built P/S bike motors (Suzuki) for many P/S racers. IE...he knows his stuff.
Old Apr 14, 2004 | 08:06 AM
  #153
uluz28's Avatar
Bob--
What CR was/is that Cobra running (your engine builder)?
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
