More Mustang.
Old Sep 25, 2003 | 06:27 PM
  #16
PacerX's Avatar
Look, at 275rwhp it either goes on a helluva diet (doubtful...) or it gets the smackdown.
On average, V8 Mustangs were about 50 lbs. heavier than the LS1 F-cars.
If I were stock, I'd fear no Mach 1.
Old Sep 25, 2003 | 10:14 PM
  #17
Schismblade's Avatar
Originally posted by hp_nut
The average Mach1 rated at 300hp is actually dynoing 275 at the wheels. That's about 325 real crank. So Ford definitely underrated the Mach1.
The average mph is about 2 less than LS1 which translates to about 20-25 hp difference.
So the current "officially rated 300hp" Mach1 is explainable running low 13s @ 106.
I guess the question is will the 300hp 3V in the '05 be underrated or will it be really 300 meaning it should dyno around 255 at the wheels and run significantly slower than an LS1.
But... word is LS1 performance is the target for the GT and coupled with the reports of test mules dynoing 275 at the wheels suggests that the '05 GT will run about where the current Mach1 is.
Last time I heard, 300rwhp beats 275 rwhp.
Old Sep 26, 2003 | 08:27 AM
  #18
IZ28's Avatar
I think they should just keep making the current car LOL!!
Old Sep 26, 2003 | 12:21 PM
  #19
Z284ever's Avatar
I don't think Ford will do another BULLITT...due to legal issues, but I thought this was neat.
http://home.comcast.net/~tuki12/index5.html
Old Sep 26, 2003 | 09:27 PM
  #20
guess who's Avatar
4.6 3v with VCT which "should" give it one hellofa torque curve I dont see (depending on what gear Ford puts in the GT) getting with a LS1 F-bod would be all that hard.But then again there is the weight issue.Nobody knows what that is or will be.
FWIW,Alot of MACH1's are in the neighborhood of 335hp at the crank.But I like to believe 325hp is a lil more accurate.
Old Sep 27, 2003 | 12:14 AM
  #21
RiceEating5.0's Avatar
The Mach-1 is 100+ lbs heavier than the current GT and has the heavier 32v 4.6 in it as well. So far, they've dyno'd 275rwhp and have smacked down low 13 sec passes at 106-107mph (hmmm Ls-1??). Motor Trend got a 13.2@106.7mph. MM&FF has gotten 13.0's, and 5.0 mag 13.1's. The dyno’s are not ls-1 #’s, but the ¼ miles sure are.
The 32v 4.6 is also said to be peaky. The Sohc 3v should have a better low-end which might help somewhat. For the most part, that's what the 32v motor lacked.
Really? I thought the Ls-1 cars were heavier. In fact, the BASE 3.8L f-bod has a higher published weight than even the v8 GT. Here are the numbers off carpoint. The below are 2002 coupe models (last year f-bod made) with manual transmissions. No Cobra for 2002.
Base model:
Camaro: 3,323lbs
Mustang: 3114lbs
Mid models:
GT: 3,273lbs
Z28: 3,411lbs
Now unless these #’s are way off, the Mustangs in general are lighter. What #’s did you have in mind?
It's capable of giving you a really good run; especially seeing as how it runs well into Ls- territory. Fear? No. But i wouldn't get overconfident. It could very well turn out to be a driver’s race.
Old Sep 27, 2003 | 10:38 AM
  #22
Outstanding numbers, but LS1s are well capable of getting into the 12's stock and it doesn't take a professional driver to do it. I've been to the track a few times and I've never seen lower than a 13.6 from a Mach 1.
Yeah, LS1s are a bit heavier, Mustangs have to deal with more drag though...it's a toss up.
I've taken one by a car length and a half with my 13.49 @ 106 LS1. Nothing really special, but it was enough to get the job done. I'm an average driver at best, I won't fear.
Old Sep 27, 2003 | 12:51 PM
  #23
My point was that the bulk of Ls-1 cars are in the lower 13's. You've seen the dyno variations yourself. One will dyno 320rwhp or 315rwhp and another 290rwhp or 300rwhp, with many falling in between.
True. I think the CD for the Gt's is .34 and z28's .32. 2 tenths advantage. We're not talking about a huge aero advantage here. Then again, the extra 100lbs or so in the ls-1 cars is easily overcome by their superior Hp and tq output. In the end, the aero or weight advantage means little.
The Mach’s advantage is in the gearing since it comes with factory 3.55’s, which can be considered a mild performance gear.
True, I never said you had anything to fear. I just said don't be overconfident because it could very well turn out to be a drivers race since the two cars are pretty close.
Btw, the Mach is available in Auto which is said to be over half a second slower than the 5spd. That makes a world of difference.
Old Sep 27, 2003 | 11:18 PM
  #24
guess who's Avatar
Riceeating5.0
LS1's with the M6 come with 3.46's.Far from the 3.27 in previous years of the DOHC 4.6...3.55 in the MACH are what should of been in the 4.6 cars years ago,It would of been more inline with the F bod.Then again the LS1's had that 6 speed.
Old Sep 28, 2003 | 01:19 AM
  #25
Z28Wilson's Avatar
I know it's cammoed and all but still, every angle I view that car from I think.....
Frumpy. :blah:
Old Sep 28, 2003 | 07:53 AM
  #26
SNEAKY NEIL's Avatar
4th gen M6's have 3.42's.
Old Sep 29, 2003 | 08:24 AM
  #27
Jackass's Avatar
I really liked the silver coupe concept's proportion. I have a deep feeling that Ford will F it up.
Old Sep 29, 2003 | 10:12 AM
  #28
guionM's Avatar
Thumbs up Here it is undisguised
Someone at BON did the car without the camoflage.
http://warnerrobert.com/ubb/ultimate...c;f=2;t=001736
Old Sep 30, 2003 | 05:11 PM
  #29
snorkelface's Avatar
Re: Here it is undisguised
It kind of looks like a current Mustang with a bodykit.
cmsmith
Apr 10, 2015 10:03 AM
NewsBot
Apr 7, 2015 10:50 AM
cmsmith
Jan 5, 2015 07:04 AM
NewsBot
Dec 3, 2014 12:30 PM
Pentatonic
56
Feb 12, 2003 03:41 PM
