GT500 mule info
Re: GT500 mule info
Originally Posted by Z28Wilson
Why would IRS bump the price of a Mustang GT up $4,000? It has been noted that Ford is saving only a few hundred dollars per car going with the live axle.
. In that case, you're going to need a bit more than a simple 300 dollar IRS
.I wonder if that 300 dollar IRS is a quality unit or a cheap 99-04 Cobra-like afterthought. Either way, a quality IRS for 300 bucks (some would be willing to pay upto a grand, me included) would be a VERY worthwhile option assuming it improved handling considerably. Sure beats spending 1,300 bucks on that overpriced 1000watt Shaker1000 audio system. As an option, you'd keep those budget minded and drag racers happy, and those willing to pay a bit more for a better rear suspension happy as well. Perhaps Ford is or should be thinking of this for the near future. But i don't want a half-asses effort. If they're going to do it, it had better be a quality unit and not some budget-contrained afterthought.
Re: GT500 mule info
True, "just any" IRS doesn't cure all handling issues....a quick peak at the GTO will tell you that (it isn't terrible but it isn't world class either, although weight may play a roll as well). Luckily from the hints Charlie has been dropping, the next Camaro's upper models will have an IRS with serious handling capability in mind. I like the sound of that.
Let's just make sure the wheel-hop issues are minimal!
If I were to guess, the GT500 will handle as well or maybe slightly better than my SS. After all the rear end setups are virtually identical. I don't consider my car to be a bad handler at all....it just gets scary when you get after it on a Michigan country back road. That's been my whole point with the solid axle vs. IRS debate...on a glass-smooth track surface, sure you can get great on-paper g force and slolom numbers....great for marketing....let's see the rear end not jounce all over the place on a pothole-scarred two lane road.
Let's just make sure the wheel-hop issues are minimal!If I were to guess, the GT500 will handle as well or maybe slightly better than my SS. After all the rear end setups are virtually identical. I don't consider my car to be a bad handler at all....it just gets scary when you get after it on a Michigan country back road. That's been my whole point with the solid axle vs. IRS debate...on a glass-smooth track surface, sure you can get great on-paper g force and slolom numbers....great for marketing....let's see the rear end not jounce all over the place on a pothole-scarred two lane road.
Re: GT500 mule info
They've shown they can build mustangs capable of world-class handling (80's SVO's and later Cobra R's), but they came at a cost and both were drastically different than the normal mustangs.
Re: GT500 mule info
Originally Posted by Gold_Rush
I wonder if that 300 dollar IRS is a quality unit or a cheap 99-04 Cobra-like afterthought. Either way, a quality IRS for 300 bucks (some would be willing to pay upto a grand, me included) would be a VERY worthwhile option assuming it improved handling considerably. .
This system was cheaper, lighter and worked better that the DEW98 system.
If there were competition from an '05 Camaro, I'd bet that this IRS would be under Mustangs right now.
Re: GT500 mule info
Originally Posted by Z284ever
It would have been based on the excellent Control Blade IRS from the AU Falcon. http://www.trueblueford.com/BA_suspension.html
Re: GT500 mule info
Originally Posted by 91_z28_4me
Instead of appearing when the next Camaro comes out. Ford has done the R&D and I am sure it can go across the board now if they wanted. But if you can make extra money on EVERY model because the closest comparable competitor is out to lunch then GO RIGHT AHEAD!
Re: GT500 mule info
I'd be disappointed if it was equal to or slightly better than a 2002 SS. That'd mean it's really no improvement over the previous gen Cobra's. That I find hard to believe. Perhaps I just have higher expectation for it.
CARiD
Sep 7, 2015 08:21 AM
