2007 ford shelby GT500 to come with its own gravitational pull
Old May 5, 2006 | 02:14 AM
  #46
RussStang's Avatar
Re: 2007 ford shelby GT500 to come with its own gravitational pull
Originally Posted by DrewSG
The 5.4 was never meant to be a performance car engine.
You could argue that the 4.6 never was either. Did the 4.6 not debut in the trucks first, before the Mustang? My memory is hazy here, as the 4.6 has been around for a long time now.
Old May 5, 2006 | 02:57 AM
  #47
Bob Cosby's Avatar
Originally Posted by SSCamaro99_3
I apolgize for inferring that that was all that they are capable of. I am aware that many run far beyond that. I do find it more or less curious that OHC gets touted for all its rpm capability, and efficiency, and Ford went a built something (that in every day use) is heavier, less effecient, more complex, and does not have a distinct rpm advantage (in stock trim) over its direct OHV competitors.
Can't (and won't) argue with that.
There is no arguement - neither was developed as a performance engine. The Modular engine layout was designed to be used in a variety of configurations and in a variety of platforms. That, in and of itself precludes them being designed primarily with what most of consider "performance" in mind.
Then again, you could probably say the same about most engines that have ever been massed produces (notice I said most, not all).
Bob
Old May 6, 2006 | 03:54 PM
  #48
guionM's Avatar
If I remember, the main purpose Ford had in developing their OHC V8s was that it was both concieved as easier to add future technology such as VVT, and DOHC was seen as necessary to compete with the then new age of luxury cars such as Lexus & Infinity.
Also, if I remember my history, Ford originally was co-developing the engine with another company but had a number of areas where they disagreed (one instance was Ford wanted timing chains for durability while the the other company wanted nylon for less noise). In the end Ford decided to go it alone.
Old May 6, 2006 | 07:14 PM
  #49
bossco's Avatar
I dunno, in the world of Ford, the 4.6 is like an epoch ahead of the old windsor motors. I've been reading about a 5.0 liter mod motor build up using ported stock 2v heads, aftermarket cams, high compression (as if they had a choice) and a factory intake. The rascal put down 425hp, then fitted with a sheetmetal intake in knocked down 490hp.
I don't think I've ever seen a 5.0 with ported factory heads (E7TEs), high compression, and an aftermarket bumpstick put down 400+hp let alone almost 500hp with a custom intake. Well at least that easily. I'd even say the 347 I got collecting dust in my garage would be hard pressed to put out 500 hp and all thats stock on it is the block.
Old May 6, 2006 | 11:15 PM
  #50
Speed_Kills's Avatar
I've seen a friend's 351 put down 500+ on an engine dyno but it was almost a race engine.
Back to the shelby. If they used the Viper's T-56 ratio's {.75 and .50} with a 3.55 rear end. I imagine it would get decent mileage.
DirtyDaveW
Mar 15, 2015 07:01 PM
canbaufo
Feb 24, 2015 10:27 AM
NewsBot
Dec 3, 2014 12:30 PM
bossco
Nov 29, 2014 10:18 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
