2005 Mustang GT to handle better than 2002 Z28?
Re: 2005 Mustang GT to handle better than 2002 Z28?
Originally Posted by PaperTarget
Don't forget that 18's are an option...
18s are a step in the handling direction but they still gotta grip
i'm not tryign to incite you, i'm just curious at what size of tire they will have
Originally Posted by unvc92camarors
what kind of meat will they have though?
Last i heard, the 18's were cancelled or put off for a year or so on the GT. Will we see it from the get-go?
255/18's are decent at best, but 275's would have been perfect
. Are the 18 inchers 18x8 or 18x9?
From the looks of it, the rear end suspension looks a lot like how the third/4th gens were set up in the rear. LCA's. panhard/track bar. All thats missing is the torque arm.
anyway, I guess we will see. My only question about the Mustang is why doesnt Ford move up with the rest of the world, and offer a 6spd manual in the GT?
Chances are you'll still be able to put something slightly wider than 255 on there even with 18x8's.
Hmmmph, the new M*stang's setup is alot like 3rd Gens and 3rd Gens do handle better than 4th Gens. But 3rd Gens are more harsh when it comes to ride quality. To be honest, I really don't care as neither can match an IROC-Z. (.92 g best!)
I just can't see any M*stang outhandling any Camaro.
I wonder if the 5th Gen will be able to go beyond that .92g F-Body high.
. Are the 18 inchers 18x8 or 18x9?I heard 18x8.......for the GT.
[QUOTE
I just can't see any M*stang outhandling any Camaro. [/QUOTE]
ANY?? It's been done. The 2000 Cobra R pulled 1.01g's. . Now I know you're going to argue that it wasn't a regular production car. However, the current Cobra skidpads a little above 0.9g's, pretty close to the IROC's 0.92. If the current Cobra skidpads at 0.9, then I would expect the next Cobra with it's new stiff chassis, wider track, and a desire to outdo the previous generation will pull at least 0.95, probably closer to 1.0g.
I just can't see any M*stang outhandling any Camaro. [/QUOTE]ANY?? It's been done. The 2000 Cobra R pulled 1.01g's. . Now I know you're going to argue that it wasn't a regular production car. However, the current Cobra skidpads a little above 0.9g's, pretty close to the IROC's 0.92. If the current Cobra skidpads at 0.9, then I would expect the next Cobra with it's new stiff chassis, wider track, and a desire to outdo the previous generation will pull at least 0.95, probably closer to 1.0g.
I have two thoughts:
What is 'curb weight'? My '94Z was weighed at a Pro-Solo event with 5/8 a tank of gas and came in at 3350. Is curb weight meaning all fluid tanks full?
Also, really what we're comparing is a 2005 chassis to a 1993 chassis, or 1998 if you want to split hairs about the slight suspension tweak in '98. My second biggest beef with the '05 'Stang is it still uses a glorifed pick-up's rear suspension.
Yes. Thus my biggest beef with my car as well.
Like the current Sn95's, the Cobra's IRS unit should bolt right in, so there should be some flexibility as far as rear-end options for the hard-core track guys (albeit not from the showroom).
