'05 Mustang HP numbers are leaking out...
Originally posted by ProudPony
I've heard nothing new on the V6 cars yet, so I'm assuming they are the same basic 200hp units we have out now - it is after all the base V6.
SNEAKY NEIL, 275rwhp is not LT-1 #s. But i'm assuming you were reffering to the 255rwhp low-side figures. But i highly doubt that low 255rwhp figure. I personally think the GT will be rated over 300hp. I don't know why you’re set on thinking it'll be lower
.USHotRod, Depending on weight of the GT, and gearing, the new GT might be right smack in Ls-1 territory. There's Ford playing catch-up with the GT once again
. The 3400lb-3450lb 305hp Mach-1 which also dyno's at around 275rwhp has already layed down some good low 13 sec 1/4 miles. MM&FF has gotten 13.0 figures and even Motor Trend pulled a 13.2@sub-107mph times with a 5spd Mach-1. The current GT weighs in the 32XX's. Assuming a 100-150lb weight gain to Mach-1 weight or even a weight-loss, 3.55 gearing, the 3v 4.6 having more low-end grunt, and it coming with a live axle; this low 13 second 1/4's could very well likely be duplicable with a new GT.
This thread is everywhere.
http://warnerrobert.com/ubb/ultimate...c;f=2;t=001673
http://forums.bradbarnett.net/index.php?showtopic=724
http://forums.stangnet.com/showthread.php?t=370178
oops...
maybe I said too much?
My point is, how do you know that the 275 hp should be the one quoted? It seems to me that the lower numbers would be more believeable because you are not going to restrict the car when testing it on a dyno, but, someone could easily do a few things to bump it up. We don't know how many cars dynoed what to see if there are some patterns. Maybe all of the cars but 1 were in the 250-260 range or maybe all but 1 were in the 265-275 range, we don't know. So until the new car comes out and real people get some baseline numbers, I will stay on the conservative side................and I still believe that the new GT will be rated below 300.
. A rating of less than 300 will be a real dissapointment though.
I myself have not seen any data sheets from an actual dyno run, but my understanding is that the cars (I am referring to anyways) were dyno'ed in stock trim to establish a baseline for engine performance and design parameters for add-on equipment. I really don't think any of these were "ringers" or factory freaks - especially this early in the game. Remember, these cars were released under confidentiality contracts - they were CERTAINLY not released to the press for thrashing and rag-stats.
I have been honest about it... I'm not the guy who dyno'ed the car(s).
Just take it for what it's worth.
that's exciting news about the GT. But I thought there was talk of putting the truck based 4.0 (or was it 4.2?) in the base V6 until the Duratec 3.5 was ready. And if the 3.5 will only be ready in 2006 then technically it won't make it into the new Stang for 2 years.
The new Mustang is a 2005 year model. The 3.5 will come out in 2006 year models. That's 1 year after new Mustang is introduced, not 2.
Another thing to note here is that no 2 dyno's will produce the same numbers.
http://info.detnews.com/autosinsider...x.cfm?id=10953
I thought this was interesting.
"Look for Mach and GT variants to continue, followed in model year 2006 by an all-new SVT Cobra"
I thought the Mach-1 was limited to a 2 year run (03/04). Has Ford changed their mind and decided to keep the Mach-1 around much longer? If so, that's really good.
I'd like the lineup to look like this:
base= sub-250hp 3.5L 24v duratec
GT= 300-315hp 4.6 24v modular
Mach= 350-390 5.4 32v N/A modular (think 390hp Falcon GT)
Cobra= 460-500hp 5.4 32v S/c'ed modular
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
