Going to racing school, what should i take?
You have to be careful with weight transferring back to the unloaded suspension like that. Especially with stock springs, shocks and sway bars. Try to hesitate for a second when the steering wheel is in the 'straight ahead' position. That will lessen the momentum that builds up as it transfers from one side to the other. Easier said than done however. Watch this video.
http://home.cfl.rr.com/sscamaroconv/...cond%20Run.WMV
50 seconds into it, that is what happened to me. The lefts were loaded hard. When I turned back to the left the rear end snapped back around too far. Since I had already blown the run by missing a gate right in front of the camera I just kept my foot in it and put on a little show for the crowd. That's one way to get rid of any flat spots
As said before, springs and other upgrades should help. Short of that, shocks and sway bar will probably give the most improvement for the least amount of $$$.
My $.02
. As said before, springs and other upgrades should help. Short of that, shocks and sway bar will probably give the most improvement for the least amount of $$$.
My $.02
....but i'm still back to the original problem...it's a police car and i have to justify every penny if i want some kind of addition outside of stock. i begged for the SFCs before those were approved. it's going to be more on me learning how to handle the skidding over adding parts to compensate.
There are 2 ways to think about this:
1. You could buy the brake pads and/or tires yourself. For the sake of the bumpers of all cars in your run group, please bleed the brakes with good fluid (Ford HD, Motul 5.1) at minimum.
2. If this is really to be a learning exercise, shouldn't you drive the car as it is on the street? Learning it's limits on R compound tires and race brakes sounds like a quick way to learn to overdrive the car on RSA's and stock pads. Still flush the brake fluid.
i will never drive this car as hard as i will next monday. driving on public roads usually warrants a little more caution than a race track.
i'm getting the brake fluid and the pads. i'm stuck with the RSAs.
Originally posted by mitchntx
DV...
you ... yes
your radio ... no
I think yer gonna have a hard time keeping up with the Jettas
DV...
you ... yes
your radio ... no
for 12 hours a day i drive the way most people only dream of.
