Window Installation
Old May 27, 2008 | 01:44 PM
slugo17's Avatar
Window Installation
Can anyone give me step by steps or a website that shows step by step on installing a passenger window in a 94 Camaro. Power windows and locks if that matters. Thanks in advance.
Old May 31, 2008 | 11:42 PM
slugo17's Avatar
No one?
Old Jun 1, 2008 | 06:24 AM
BLDun's Avatar
Are you wanting to install the window itself or the drive motor?? If it's the drive motor I believe there are some pics/instructions on shoebox's site
Old Jun 1, 2008 | 11:56 AM
slugo17's Avatar
The window, I could pay 35 dollars to do it, but if its possible I'd like to learn myself.
Old Jun 1, 2008 | 01:10 PM
BLDun's Avatar
It would almost be worth the $35. You have to remove the door panel and then the entire scissor assembly inside the door has to be removed and then you will find that the glass is held to the track by - I think it's 3 - large pop rivets. Unless you have access to a large rivet gun you can't reinstall the same size ones again. Some put bolts through but the rivets work better. It is quite a job and getting it back into the slot and lined up on the track is no picnic either. If I could find someone that would do it for $35 I'd pay it, and I have done one before. Just my two cents worth.
Nov 18, 2023 07:21 PM
Keenan
Jan 19, 2023 12:24 PM
warmeck
Feb 2, 2015 12:44 AM
Collector Car
Jan 5, 2015 10:58 AM
The Seer
Nov 20, 2014 06:32 AM
