What size rims?
Old Feb 23, 2003 | 10:34 PM
1996 | Z28 SS's Avatar
What size rims?
What are the biggest rims I can fit on my 96 SS without doing any hammering?... or at least very little hammering
Old Feb 23, 2003 | 10:59 PM
aircop40's Avatar
hey whats up, i have 19's on the front and 20's on the back and did no modifications at all to the fender wells. i have seen 20's on all 4 corners too without any hammering. i think it depends on the width you go with though. lata
Old Feb 23, 2003 | 11:21 PM
chuckys95's Avatar
Re: What size rims?
width or diameter ?
Old Feb 24, 2003 | 02:40 PM
275mm width
Old Feb 24, 2003 | 03:34 PM
What wheels "fit" is an issue of the overall tire diameter, not the wheel diameter. As long as you get the correct offset on the wheels, and the correct outside diameter on the tires, they will fit just like the original wheels/tires. In general, I haven't seen too many people go wider that 9.5" on the front, and a 275 or 285 section width tire. You can live with anywhere from 45mm - 56mm offset, depending on how close you want the outer edge of the tire to the fender line.
In the back, you can go up to 11.0" width, with a 315 section width, with minor "hammering". Best setup is with a 50mm offset.
You can look at combos like 275/40-17 or 285/40-17; 275/35-18 or 285/35-18; or 285/30-19. Where you will get into trouble is with the 20" diameter rims, because the 275/30-20 tire will be about one inch larger in diameter than stock, which pushes the tire 1/2" further up into the wheel well, and raises the body 1/2" more off the ground.
If you need need details or photos showing the mods for 11" wide rims in the back, let me know.
Old Feb 24, 2003 | 03:56 PM
SS LS1 MI's Avatar
Listen to Injuneer, he is right on track with what will fit and he won't steer you wrong with tire/wheel selection. (pun intended)
Old Feb 25, 2003 | 12:15 PM
KillerTA's Avatar
Re: What size rims?
20's all around
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Formula Steve
Sep 19, 2015 08:48 PM
scottcba1
Sep 8, 2015 09:52 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
