Tire width question
Old Jun 9, 2003 | 08:03 PM
Maninthebox's Avatar
Question Tire width question
Yo guys how wide a tire can i run on 98 camaro 16x8 rims without problems thanks
Old Jun 9, 2003 | 08:06 PM
StreamlineZ28's Avatar
the max i would run on the stock wheels woud be a 255. but i dont even know if i would do that i would probably just stick with 245
Old Jun 9, 2003 | 09:32 PM
The problem isn't what width fits on a 16x8 wheel, as much as it is "what tires are available?" Most manufacturers recommend a rim width of 7" - 9" for a 255/50-16, so there is no problem at all with putting a 255 on our stock rims. But you will find that the tread width varies so much on a given size tire, from manufacturer to manufacturer, and even within specific models from the same manufacturer, that there may be little if any real difference between a 245/50 and a 255/50. The theoretical difference is 0.40" wider section width and 0.40" larger outside diameter.
Problem is no one makes a performance street tire in anything wider.....
If you go to Tire Rack and start putting in various size combo's, the only tires that come up in the search are things like the Hoosier road race and auto-X tires. They have a 275/45-16, and they recommend a wheel width of 8" - 10" for it. Only problem is no tread depth, and a very soft compound with little tread life, and problems in the rain.
Ken Cemo
Feb 13, 2015 08:37 AM
Ken Cemo
Jan 27, 2015 08:45 AM
Jason Short
Jan 19, 2015 06:33 PM
Hurin
Dec 13, 2014 07:38 PM
nophix
Nov 30, 2014 10:26 PM
