Switch Plate finished... How do I hide the glue?
Old Feb 1, 2005 | 10:44 PM
Need4Camaro's Avatar
I made a Switch Plate out of Plexi Glass where the old Den used to be right infront of the shifter on the 97 + Models... However since it's glass, it also shows the glue I used to mount it with. I was asking for ideas as to how I could hide the glued outlines under and on the edges of the plexiglass / dashpanel... I was thinking maybee a plastic frame to fix this up!... Where can I get a frame cut right though?
Old Feb 1, 2005 | 11:40 PM
AW/whiteZ-28's Avatar
Re: Switch Plate finished... How do I hide the glue?
Why not paint the panel to match you interior?
or if you want the clear look use polished screws to hold it on.
Old Feb 2, 2005 | 12:46 AM
Z95m6's Avatar
I would just paint it. If not the polished screw idea isn't bad either.
Old Feb 2, 2005 | 09:56 PM
L44's Avatar
L44
i tinted my plexi glass with 5% before i worked on it
Old Feb 3, 2005 | 12:20 AM
I didn't paint it because I had a light up switch and thought it would be cool to see a lit up switch at night...
It's glued on there so I can't paint it now... even if I could it still wouldn't hide the glue deposites that surround the Plexi Glass that are stuck on the console... I was thinking I could hide it with a Frame but any other ideas?...
Old Feb 5, 2005 | 11:25 PM
I was thinking maybee a frame from a plastic shop that would hide the glue on my Plexiglass and Plastic Interior spot... Any other ideas?
Old Feb 6, 2005 | 10:48 AM
Brent94Z's Avatar
Super Moderator
Go purchase some pinstripe material of the proper width from an auto parts store. Put a pinstripe border around the edges to bascically make the very edges black (or whatever color) and this will hide the glue.
Old Feb 6, 2005 | 03:10 PM
Good idea...
Old Feb 7, 2005 | 08:01 PM
Brent94Z's Avatar
Super Moderator
Originally Posted by Need4Camaro
Good idea...
Thank you
Old Feb 7, 2005 | 10:35 PM
Thank you
Did it! looks MUCH better... I have a question... in the future when all the switches are completed, is it possible to have a plastic shop or someplace wield the PlexiGlass to the plastic for a more natural look?
Old Feb 8, 2005 | 11:56 AM
Brent94Z's Avatar
Super Moderator
Yes. But, that "yes" depends on how much you want to spend... if you don't do plastic/fiberglass work yourself, having somebody else do it (and do it custom) can get expensive.
Old Feb 8, 2005 | 07:57 PM
Eeeek even for just a 3 1/2" X 2 1/2" frame?
Btw Brent I wanted to order some 30th Anniv Seat Badges and Nose Badge from you!
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
95blkss
Sep 22, 2015 03:18 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
