Sun Visors
Old Jun 26, 2003 | 05:51 PM
Darklighter's Avatar
Sun Visors
The elastic on the sunvisors on my '95 Z28 seem to have melted. The strap now sags and is no longer stretchy. I plan on going to the dealership tomarrow to see if I can order new ones because they are ugly. Anyone know if this is a common problem with the visors and if I should order ones from a '98 or later and if those will fit. My friend has a '98 Trans Am and it has visors with a different elastic material so I was thinking maybe they found them to be a problem and upgraded them. Thanks.
Old Jun 26, 2003 | 06:03 PM
SloMofo's Avatar
Re: Sun Visors
The eleastic wearing on them is common. They were worn when I bought my car. I just stuck a needle in em thru the visor and it held it up great and you couldn't see it.
I have since gotten new visors
Old Jun 26, 2003 | 09:25 PM
Brent94Z's Avatar
Super Moderator
Very common problem. However, I'm pretty cheap so my fix is to open the mirror lid, take the elastic and stretch it up to the mirror, then close the mirror lid and "capture" the loose elastic. Problem solved
Old Jun 26, 2003 | 09:28 PM
AW/whiteZ-28's Avatar
Just cut them off that's what I did I forgot I had them for awhile
Old Jun 27, 2003 | 08:07 AM
z28jaz's Avatar
Same thing happened with mine. Im pretty tall and never used them anyway so I just took them out and made some plates out of textured ABS to cover the holes they mounted in.
Old Jun 27, 2003 | 08:19 AM
blu94Z's Avatar
Same thing happened on my '94 Z28. The elastic seems to degrade more quickly in hot weather. I muddled along by sticking the elastic in the mirror, but eventually replaced them before I sold the car. They're expensive, about $50 a piece from the dealership, and they are a little bit different from the original visors. Just some of the woes of owning a car for more than a few years.
2QUIK6
Sep 17, 2016 02:31 PM
WPHIG2
Aug 27, 2015 06:37 AM
Boss002
Jul 24, 2015 10:47 AM
Jul 10, 2015 02:23 PM
