A smurf got ahold of my gauges!
Old Sep 6, 2003 | 12:12 PM
  #31
96 TA's Avatar
Old Sep 10, 2003 | 12:14 PM
  #32
pu12en12g's Avatar
You guys are using the Single LED bulbs not the Quad LED bulbs correct ?
Old Sep 10, 2003 | 01:17 PM
  #33
350 HRSS's Avatar
This is an excellent post!
You did a great job! Thanks for the great diagram!
Old Sep 10, 2003 | 08:52 PM
  #34
Capn Pete's Avatar
Lightbulb
I only found out when I changed my bulbs the other day (I went with RED!!) that the gauge cluster changed a little from the LT1 to the LS1 F-bodies, so that diagram only applied for a couple of the bulbs (I had to guess at a couple ). I got the main cluster to be all red though, and it looks sweet. HOWEVER, my light switch and heater controls are still blue-ish, green-ish, white, because the bulbs that they take are these tiny, tiny little bulbs that are about 1/2 the size of the 194 bulbs. Does anyone know if they make colored versions of these bulbs as well??
T.I.A.
Old Sep 10, 2003 | 09:06 PM
  #35
z28_melissa's Avatar
thats a good question... i wanna change my heater & shifter lights too. maybe if someone has a haynes manual it would say the bulb size in there?
Old Sep 10, 2003 | 09:39 PM
  #36
AW/whiteZ-28's Avatar
It's the same size as the ones that light up the door switches on 93-96's
Old Sep 10, 2003 | 09:54 PM
  #37
Capn Pete's Avatar
Arrow
OK, but does anyone know the size or #, and do they come in colors other than white??
Old Sep 10, 2003 | 09:55 PM
  #38
and what size are those?
Old Apr 20, 2004 | 07:36 AM
  #39
94BlackBowtie's Avatar
Let's bring this one back to the top...it has some great info in it...
And the last two questions have now been answered.
Old Apr 20, 2004 | 08:43 AM
  #40
Eliminator's Avatar
They look cool. I have blue piller pod lights and wanted to do the same to everything else.
Old Apr 20, 2004 | 09:06 AM
  #41
phrozen's Avatar
Isn't the film used on the stock gauges slightly blue so that the yellowish bulbs they use stock shine through green? I ask because I thought I had seen someone stick white LED bulbs in and had them glow blue.
Old Apr 20, 2004 | 09:11 AM
  #42
Originally posted by BIGKerneL44
the ones for the doors use either a 3mm LED or drill the hole out a little for the 5mm, the regular gauge lighting use #194 bulbs, other accessory lighting such as the HVAC controls, the traction control, vents use either a 3mm or 5mm LED
DEWD! Where have you been lately, haven't seen you.
BTW - That is correct information - but that is the hard way to do it. Didn't you read the new thread about there being miniature bulbs that just plug and play now?
Just order some 74 bulbs from the place mentioned in the other thread and you just plug them in - no need to buy 3mm or 5mm's.
Other thread is located here BTW. It's on the main app. page.
Old Apr 20, 2004 | 03:36 PM
  #43
Capn Pete's Avatar
Awesome!! I'm definitely going to have to look into this...........I've been driving around since September now with red dash lights and blue/green HVAC and light switch back-lights! It's retarded!
Thanks for the update!
Old Apr 21, 2004 | 11:39 PM
  #44
I CORNER's Avatar
Looks great! I notice that the illumination is a little dim from 4000 to 5000 rpm on the tack. My white-face conversion with stock clear bulbs has the same slight faded appearance. Must be a spot where the light can't fully reach.
I don't have a night photo like yours but here goes.
White faced gauge conversion
Rick R
Old Aug 26, 2004 | 07:32 AM
  #45
mshrmhd's Avatar
Re: A smurf got ahold of my gauges!
the black twisty things that the bulbs go in that lock into the cluster... how does one go about getting a few extra of those? like a part number or something.. i wanna play around with some extras thanks..
