Shorting automatic shifter
Old Feb 25, 2005 | 10:25 AM
SUMO-Z's Avatar
Does anyone have a write up on how to do this? Dont you cut like an inch off of it?
Old Feb 25, 2005 | 03:12 PM
94ZRiCeKiLr's Avatar
Re: Shorting automatic shifter
its fairly easy... the **** comes is held on with a large staple looking thing that's pressed into the front of it (where your fingertips would be). pry that out and the **** should pop right off. there's a white plastic rod in the middle of the shifter shaft. you have to use a dremel cut off wheel or something and shorten the outer shaft first. and then the white plastic rod BY THE SAME AMOUNT (ex: if the white rod sticks an inch out of the shaft, make sure you only cut an inch off it). if you cut it flush with the top of the shaft, the button on the top of the **** won't unlock the shift linkage anymore.
grabbem88
20
Dec 27, 2015 07:42 PM
PROJECT X
Apr 17, 2015 12:13 AM
nikolt1
Feb 27, 2015 09:10 PM
ferraricameron
Jul 29, 2002 07:46 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
